Does Moving a Magnet in Free Space Radiate?
  • Level: Graduate
  • Thread starter Thread starter sahil_time
    Magnet
16 replies · 4K views
sahil_time
If i move a magnet back and forth in free space, will it radiate?
If it does not then why?
Vanadium 50 said:
Yes.
Why is it not used for practical purposes? Is it because it cannot produce high energy radiation?
you got a vague answer because you asked a vague question
there is a magnetic field out around a magnet regardless of if it is moving or not
its used for many many different things ... electric motors just to name one
what hi energy radiation ? ... a magnet produces a magnetic field
cheers
Dave
But that is due to change in flux linkage, imagine a magnet in absolute free space. If i were to
then move it back and forth, will it emit radiation just like an antenna?
Move a magnet past a coil of wire (or move a coil past a magnet - the choice is yours) and a current flows in the wire. This is the basis of electricity production... essentially all thermal power stations and wind farms generate electricity using this process (solar PV panels don't).
Energy taken from a moving magnet is used for practical purposes all over the world (but in case you're thinking you'd like to get some of that free energy, remember you're only taking out at an absolute maximum the same amount of energy you put into move the magnet in the first place.)
Far from this not being used for practical purposes, I'm honestly having trouble thinking of a phenomenon in the modern world put to more frequent practical use.
ok, just read your latest post ... slightly different question then.
But now I don't get it - you're thinking of something like, say, the Earth - a big magnet moving in space? It has a magnetic field around it that moves with the earth. It doesn't "emit radiation" due to its magnetic core any more than it emits gravitational "radiation". Maybe on a quantum level you're thinking of force carrying particles that we haven't yet identified? Can you explain what kind of practical use you're talking about... propelling a spaceship by jiggling a magnet about or something?
Okay, i think the question has been a little vague i guess. Let me rephrase.
--An electron, if moved back and forth, emits radiation. This is the basis of antenna theory.
--In contrast, any neutral metal will not radiate if moved back and forth because it is neutral and
hence does not produce a magnetic field.
--Now, if a magnet, which although has neutral charge on the whole, but has a magnetic field,
is moved back and forth, will it radiate?
I'm not really in my field (no pun intended) but I'd answer that antenna theory starts with an isolated negative charge (if we're using an electron) with a net negative charge spreading out into the universe. A magnetic pole is never isolated - you only ever (so far) see dipole magnets. By analogy you couldn't create an antenna by shaking a piece of net-charge-neutral metal. Happy to be out-argued.
Yes, it will, as Vanadium 50 said in the first reply.
The frequency of the radiation will be equal to the frequency of the oscillation of the magnet, of order 1 Hz. I don't think there is any practical use for such low-frequency radiation. Furthermore the total radiated power will be extremely low.
Electrons oscillate back and forward in a conductor when an AC current is applied
the acceleration of that charge generates an electromagnetic field which will be radiated
again, the only thing being radiated is a magnetic field
there is NO RF radiation
there's only a magnetic field, not an electromagnetic field because there is no AC current flowing to generate one
Dave
Dave
But the fact that there is a varying magnetic field must imply a varying induced electric field, surely.
∇E = -dB/dt
any change that is 'forced' onto one field (as is waggling a magnet around) will induce a change in the other.
It would be interesting to know whether anyone has gone to the trouble of spinning one of these new fangled super magnets at very high speed (100s of kHz would not be impossible) to see if the resulting RF field can be detected at a distance.
There is a changing magnetic dipole, so there is RF (assuming you call a few Hz RF) radiation. As sophiecentaur points out, the changing magnetic field induces an electric field.
The power radiated is:
[tex]<P> = \frac{\mu_0 d_0^2 \omega^4}{12 \pi c^3}[/tex]
Where the magnetic dipole is ##d = d_0 \cos(\omega t)##.
Note that for a bar magnet being shaken this is very small. Everything in the numerator is small, and everything in the denominator is big.
Plugging in numbers, I get something like 10-37 watts radiated by shaking a bar magnet back and forth.
OK
I see where you are coming from
So you are saying that the field outside the magnet is then cutting back through the magnet as the magnet moves within the field and thus generating a current which in turn is generating an EM emission
and OK so its freakin' tiny, nothing like what the OP was indicating or hoping for :wink:
Dave
davenn said:
OK
Dave
No i guess, the magnet's movement induces closed electric loops in space everywhere, that is
what Maxwell's equation suggests ∇XE = -∂B/∂t. The fact that if a magnet moves back and forth
, there will be flux change everywhere, and hence an electric field given by ∇XE = -∂B/∂t.
Also consequently, there will be a magnetic field due to the induced electric field, it will be
∇XH = -∂D/∂t . Where J = 0. So everything self propels to create RF.
Am i right?
