Does Potential Energy = 0 at Earth Centre?
39 replies · 27K views · last reply
DaleSpam said:
KE is not absolute even in Galilean relativity. Using purely Newtonian physics you can clearly see that KE depends on the coordinate system. My desk has 0 KE in the reference frame of my room, but a lot of KE in the reference frame of the sun.
ok i get it but in the universe where everything is just energy not having an absolute value of energy sounds pretty absurd does this ever bothers the physicists??
I think you are confusing two separate concepts: conservation which means that a quantity does not change over time, and invariance which means that a quantity is the same in different reference frames. Energy is conserved, but not invariant.
assuming the Earth is perfectly round, uniform density all over, and their is no gravitational interference from an outside object, like the moon, then yes. everything has to be perfectly placed into position. it works on paper but nothing can ever be measured and placed this exact. a grain of sand passing by at a distance of the center of the Earth to the moon would throw the balance off. so my answer is potential energy can never = 0
Yeah i fell a little stupid for that:blushing: but you can expect that from a commerce student!
That is EXACTLY what i though when i first saw this thread if you really start seeing things on a universal level i think the conditions can never allow potential to be zero but on a global level things are quite different.
Just goes to show that you should never trust anything at answers.com. Not a thing.
That response is a pile of nonsense. The person is confusing force with potential.
Sorry, I've read through this and I'm still a little confused.
Potential energy aside, what is the gravitational potential at the centre of the Earth (assuming constant density, and perfect spherical shape), and defining gravitational potential as the work done per unit mass moving an object from a distance of infinity to that point.
A lot of the information in this thread suggests that gravitational potential is at a maximum (a negative maximum) on the surface of the earth.
But if there is a gravitational force within the Earth's surface, this suggests to me that the potential must be greater within the Earth's surface, because the work done in getting from the surface to that point should be negative, and would be added on to the potential from getting from infinity to the surface.
In summary I'm asking what is the gravitational potential at the centre of the earth, and what is the potential slightly outside this point.
The GPE gets more and more negative but.instead of going down to -∞ (for a point mass), it follows a parabola which levels out to a minimum at the centre.
I plotted this on a spreadsheet. Also, I was interested / surprised to see that the difference in GPE from surface to centre seems to be half the GPE at the surface (wrt ∞). The analysis gives you this factor of 1/2 when you integrate the force on the way up to the surface (you get an r2/2) yet there is no corresponding 1/2 when you integrate the force going from the surface to ∞. I am assuming uniform density of course.
The vertical scale is in arbitrary units of energy, (btw)
  • Graph of GPE against radii for a uniform-density sphere, a curve rising from about -1350 at radius 0 toward about -230 at radius 3.9, with a vertical black line near radius 1.
