Does stirring water help bring it to boil faster?
  • Context: High School
  • Thread starter Thread starter AHVincent
    Boil Water
Stirring water in a large pot of over 50 liters using a 50,000 BTU commercial gas burner does not significantly expedite the boiling process. While forced convection from stirring may enhance heat transfer by keeping cooler water in contact with the pot's walls, the natural convection already provides adequate mixing. The discussion suggests that the heat generated from stirring is minimal and may even lead to increased heat loss due to wave formation. Ultimately, the consensus leans towards allowing the water to boil without interference.
  • Understanding of heat transfer principles, specifically convection.
  • Familiarity with the concept of natural versus forced convection.
  • Knowledge of the properties of water and its boiling point.
  • Basic experimental design skills for conducting heat transfer experiments.
  • Research the principles of convection and how they apply to boiling liquids.
  • Explore the effects of heat loss in boiling water and methods to minimize it.
  • Investigate the impact of pot materials on heat transfer efficiency.
  • Conduct experiments comparing boiling times with and without stirring.
Culinary professionals, food scientists, and anyone interested in optimizing cooking techniques and understanding heat transfer in large-scale cooking applications.
AHVincent
Is it faster to leave the pot alone until it boils or to stir it every few minutes to increase convection?
This is for a very large pot of over 50 litres using a 50 000 BTU commercial gaz burner at full power.
You would expect faster heat transfer from flame to water when the temperature difference is high. So stirring the water (forced convection) will keep water with lower temperature in contact with the walls of the pan and should ensure more heat goes into the water and less is wasted into the surrounding air.
My guess is that natural convection will mix it reasonably well in the first place, so there won't be much of a difference. You could always try it as an experiment (all you need is a stopwatch), and let us know the results...
And weren't Joule's experiments done by stirring a fluid? Ideally the heat generated by stirring the pot would be added to the heat from the element, I know it would be very small, but that would also shorten the time to boiling.
The stirring element might take some of the heat from the water. Waves caused by the stirring might also increase heat loss...and ultimately, you probably have to take the cover off to stir it.
I say just let it be.
  • · Replies 37 ·
  • · Replies 32 ·
  • · Replies 16 ·
