Does the electron really spin 720 degrees?
  • Context: Undergrad
  • Thread starter Thread starter Chris Frisella
    Degrees Electron Spin
71 replies · 19K views
Chris Frisella
A photon has a spin of 1, while an electron is 1/2. I've heard it said that the electron needs to spin 720 degrees to complete a full cycle. Is there any proof that the electron is spinning 720 degrees and not just spinning 360 degrees, but at a lower harmonic of the photon-- 1/2 the photon's spin frequency?
As an analogy, 2 pendulums of proportionately different mass, suspended on the same string will "feed" off each-other. If you start the lighter pendulum swinging, the heavier one will start swinging too, but at a lower frequency (and vice versa). Depending on the mass proportions, you can get the heavier one at frequency 1/2, 1/3, 1/4 or whatever you like along that line. Let's say you have it at 1/2... if you measure a whole cycle in the lighter pendulum, you'll only measure 1/2 cycle in the heavier one, but both of them are still covering the same amount of degrees.
Quantum mechanical spin should not be interpreted as the electron physically spinning around an axis. It's more like the electron simply has a certain amount of intrinsic angular momentum that cannot be gotten rid of any more than it can get rid of its electric charge.
I'm sure others can explain things in much more detail, but you can check out the following article for a brief overview: https://en.wikipedia.org/wiki/Spin_(physics)
Yes there isn't any real meaning to a point particle "spinning", that's an intrinsically macroscopic concept. A better way to think of it is that if you were to rotate the electron (or any fermion having spin 1/2) then it is symmetrical under 4π (720deg) rotation not 2π (360deg) as would be the case with the integer spin particles (e.g. photon). There *is* a physical meaning to rotating fermions and bosons, since they transform in representations of the Lorentz group, which includes the subgroup of SO(3) i.e. rotations in 3D space.
When a physical object is rotated by 360 degrees, one obtains the same object. The wave function ##\psi## of the electron does not satisfy that property, but ##\psi## is not a physical object. The product such as ##\psi^{\dagger}\psi## is more closely related to an actual physical quantity (e.g. it can be interpreted as probability density, at least in the non-relativistic limit), and ##\psi^{\dagger}\psi## does not change when you rotate it by 360 degrees.
The space of physical states is actually the space of density matrices, rather than the Hilbert space of the quantum system. Mathematically, a trace preserving representation of the rotation group (##SO(3)##) on the space of density matrices lifts to a unitary representation of its centrally extended universal cover, which happens to be ##SU(2)##. The unitary operators corresponding to ##2\pi## and ##4\pi## rotations in ##SU(2)## both map to a ##2\pi## rotation on the space of density matrices. Physical states don't feel the difference between ##2\pi## and ##4\pi## rotations. If they did, we would not be considering unitary representations of ##SU(2)## at all.
Thank you for the response. I understand that a particle conceived as a point-particle couldn't rotate all by itself. But then the very idea of a point only works when you have other points to relate it to. We know that when a particle poses spin, it can translate that into actual rotation in a mass of particles-- actual angular momentum in that mass. Definition for angular momentum: the quantity of rotation of a body, which is the product of its moment of inertia and its angular velocity.
So... if we are going to say a particle has spin, we can consider that is has rotation, or at least rotation potential. This universe, on the macroscopic scale, is considered to have 3 spatial dimensions, and 360 degrees in a circle.
Back to my original question:
This question really has to do with understanding the derivation of an electron needing to spin "720 degrees to return to its original state" as I've heard it described. Perhaps the electron is merely spinning 360 degrees, but at half the rate of the EM energy we use to measure it, as I analogized with the pendulums. Or perhaps the fact that the electron has more mass/density, that density will sort of neatly expand out under spin/rotation, thus acting like it has 720 degrees...?
Note: Anyone who wants to contribute to this thread, please keep the terminology in your answers comparable to the terminology in my question. I have no interest in taking an advanced college course to simply understand a single response in this thread ;-)
Well, if you don't want to learn the adequate terminology, why do you ask then in the first place?
Anyway, again you should forget about quasi-classical pictures of a particle when it comes to specific quantum-mechanical phenomena. Spin is one of them. No matter, whether it's integer or half-integer spin, it's not something spinning in the sense of an extended body. What comes closest to this intrinsic quantum number in classical physics is a classical point particle with some dipole (e.g., a magnetic dipole, and even in the quantum theoretical generalization you have magnetic dipole moments associated with the spin of elementary particles).
Now to you question concerning the 720 degrees to return to its original state. Already the question imposes a wrong assumption, and you have to relearn the concepts, but for this you don't need an advanced college course, but perhaps the first one or two lectures on quantum theory (provided you have a modern teacher who starts right away with the modern version of QT ;-)). What's correct is that if ##|\psi \rangle## is a vector in the Hilbert space of an half-integer-spin particle, then the rotion by ##2 \pi## gives ##-|\psi \rangle##. Now pure states are not represented by the Hilbert-space vectors but by rays in Hilbert space, i.e., Hilbert-space vectors up to a (phase) factor. The phase factor is unobservable and thus ##|\psi \rangle## and ##-|\psi \rangle## represents the same state.
A more convenient and equivalent definition of a state representative is the statistical operator, which is a positive semidefinite self-adjoint operator with trace 1. A pure state is represented by the special class projection operators, i.e., given a normalized Hilbert-space vector ##|\psi \rangle## then the corresponding state is given by the statistical operator ##\hat{\rho}=|\psi \rangle \langle \psi|##, and this doesn't change under rotations by ##2 \pi ## as it must be.
As we are at it, we go to the end of the college QT course and mention that the above arguments imply a socalled superselection rule, i.e., a rule forbidding some superpositions: You cannot have a superposition of an integer-spin particle's with and half-integer-spin particle's (or any other systems with spin), because then a rotation by ##2 \pi## would indeed lead to a different state, since an integer-spin vector is unchanged while an half-integer-spin vector flips its sign. In a superposition the relative phase between the two vectors would change, and this has observable consequences. This, however, contradicts the fact that a rotation by ##2 \pi## must not change the state, because it's the identity operator of the SO(3) rotation group.
Oh, pardon me for wanting to understand.
I already addressed this.
The answer to your question is: There is nothing physical that requires a 720° degree rotation to go back to its original state. If you rotate 360°, you are already back in the initial physical state. Your premise isn't correct.
Every explanation beyond this requires some math. Since you have marked this thread as intermediate level, people naturally assume that you are familiar with the content of an introductory course on quantum mechanics. I think vanhees' explanation in his 3nd paragraph is as simple as it possibly gets.
As I said, studying physics always includes the danger that you have to change your worldview, and if you are not willing to do so, it's the wrong subject for you. Then study philosophy and write long books full of footnotes defending your prejudices ;-)). SCNR.
You seem to have a fixed notion/delusion that I'm attacking physics. That's actually not the case; I am simply looking for answers that are tangible.
One should make physics as simple as possible but not simpler (Einstein)!
That may be true, but it's hard to wade through the abstract math.
Well, it's hard but a lot of fun too. Without math there's no way to even talk about physics in an adequate way. So if you look for tangible answers in regions where all of us have no direct intuition, because we don't observe it directly, which is true for most quantum effects, you have to learn the math and do many applications of it in QT to get an intuition about the quantum world. There's no shortcut! On the other hand, as I said, it's very fascinating and a lot of fund to learn this stuff too.
Also the math of quantum theory is not that difficult. You need linear algebra of complex Hilbert spaces and some calculus about partial differential equations. A very nice book is Susskind's "The theoretical minimum" Quantum Mechanics.
I can't really speak to the actual physics of rotating electrons, but I do know that on a quantum computer the answer is: it depends.
Specifically, what I mean is that just saying for example "a 90 degree rotation around the X axis" is not enough to unambiguously describe what you are doing to a qubit. Both the operation ##e^{i \pi X / 2} = \frac{1}{\sqrt{2}} \begin{bmatrix} 1&i\\i&1 \end{bmatrix}## and the operation ##X^{1/2} = \frac{1}{2} \begin{bmatrix} 1-i&1+i\\1-i&1+i \end{bmatrix}## are consistent with that description. But ##\big( e^{i \pi X / 2} \big)^4 = -I## (four quarter turns negates the global phase) while ##\big( X^{1/2} \big)^4 = I## (four quarter turns is equivalent to doing nothing).
Normally the difference between ##e^{i \pi X / 2}## and ##X^{1/2}## doesn't matter. They only differ in how they affect the global phase of the qubit. But once you start applying operations conditionally, controlled by the state of other qubits, that global phase becomes a relative phase.
I don't know enough about physics to say which is more common. I'd bet it's ##e^{i \pi X / 2}##, since it's ##e^\text{bla}## often shows up in the solutions of differential equations and also because, you know, people say things like "720 degrees to get back to the starting state".
You don't need to understand all the math to extract the basic reasoning: By requiring that all physical objects are invariant under rotation symmetry, mathematics naturally leads us to consider spin (Wigner's theorem + Bargmann's theorem). It just so happens that some unphysical objects only return to their initial state after a 720° rotation, but that's not problematic, since they are unphysical. All physical answers that can be extracted don't depend on this ambiguity. The same thing also happens in electrodynamics: You can add an arbitrary constant to the electric potential, but all physical answers stay the same.
Fair enough. That's helpful. Still though, I believe that a complete understanding of these problems would allow for an answer that tends towards tangability with basic English.
Ok. How do you define "unphysical" here?
If you rotate an electron through 360o, the electron's state picks up a minus sign. That's considered to have no physical importance, since the only thing of physical significance is the square of the state, and the sign disappears when you square it.
However, it seems to me that the minus sign would come into play in interference effects. I don't actually know how one would accomplish this, but conceptually, you can imagine an experiment similar to the two-slit experiment, where an electron make take one of two paths to get to a destination. Along one of the paths, the electron is rotated 360o by its journey, while along the other path, no rotation takes place. Then (assuming an electron is equally likely to take either path), there would be total destructive interference at the destination, so the electron would have no probability of arriving there.
I'm not sure what would reliably rotate an electron, though. Maybe one path has a magnetic field, and the other doesn't?
rubi said:
[...] It just so happens that some unphysical objects only return to their initial state after a 720° rotation, but that's not problematic, since they are unphysical. All physical answers that can be extracted don't depend on this ambiguity.
You seem to be saying that fermions are unphysical, which is clearly not correct since one can observe effects in, e.g., neutron interferometers (by using a magnetic field to rotate the neutrons on one side of the interferometer and then recombining).
Perhaps you meant something else?
(And let's not forget ye olde Plate trick, aka "Belt trick" or "Dirac Scissors", which shows that there are macroscopic situations where rotation by 360deg is not equivalent to rotation by 720deg.) :oldbiggrin:
@Chris Frisella : as someone else noted, your thread has become a bit of a mess because you marked it as "I", but then rejected any basic math. I'd suggest you mark such threads as "B" in future. Also, it takes a lot of effort to descramble the gobbledegook in your opening post since you're conflating a rotational transformation of a single-electron system with spinning motion. Those 2 things first need to be dissected apart. But I'm not sure how far the other answers in this thread have gone towards achieving this, so I'll wait to see what you say before I try to descramble it.
We'll take this bit by bit. Particle spin is angular momentum, correct?
That's an incomplete statement, hence potentially misleading.
First, let's call it "intrinsic angular momentum" rather than "particle spin".
To explain further, imagine a spatially extended field, hence having a spatially extended distribution of energy, stress and momentum. (Have you heard of the Energy-Momentum tensor?) Now pick an arbitrary point in space -- call it "a". Given the energy-momentum tensor of the field, we can compute the total angular momentum (denoted as "J") around "a" by a certain integral formula (which I won't write out since you don't like math). The result can change, in general, if you choose a different point "a".
Now imagine we're working in the rest frame of the system represented as that spatially extended field. "Intrinsic angular momentum" (denoted as "S") is defined as the angular momentum about any point on the field's centre of mass world line. In general, "S" is only a part of "J" -- the rest being called "orbital angular momentum" (denoted as "L"). I.e., $$J ~=~ S + L ~.$$ (Or is that too much math?)
A tentative definition would be: An object that contains ambiguous information.
However, I don't really need a definition, since I introduced this word only for the purpose of avoiding math. In the case of quantum mechanics, there is a precise meaning to it: The "wave function" can be multiplied by an phase factor without changing the physics of the system. This is similar to the case of the electric potential, which is ambiguous up to an arbitrary number (and even more). However, from these ambigous quantities, you can compute new quantities that don't have this ambiguity anymore. In the case of the wave function, this would be the density matrix and in the case of the electric potential, this would be the electric field. In quantum mechanics, only the density matrix needs to obey reasonable laws such as being invariant under 360° rotations. The wave function needn't satisfy these requirements, since you are allowed to do arbitrary nonsense to the unphysical phase factor. The reason for why the wave function is not invariant under 360° degree rotations is that the phase factor isn't invariant, roughly speaking. However, if you strip off this unphysical factor, you end up with an object (the density matrix), which behaves like it should.
I hoped nobody would bring this up. :biggrin: What you do when you "rotate" one of the fermions is not to apply a rotation (##U(R)##) to it, but rather apply a time evolution (##e^{-\frac{\mathrm i}{\hbar}t H}##) to the whole system consisting of both fermions, which happens to change their relative phase. The point of Wigner is that physics should mathematically be invariant under rotations of the coordinate system (and their active counterparts), since the choice of a coordinate system is a mathematical ambiguity introduced by the physicist. However you can't change the coordinate systems of the individual particles. Spin ##\frac{1}{2}## particles behave differently than spin ##1## particles, since they have more degrees of freedom. I wouldn't consider sending a fermion through a Stern-Gerlach apparatus a rotation. It's just an interaction with the magnetic field, which also influences the spin degrees of freedom. It doesn't rotate the particle.
No, that's not what I meant. :smile: Of course fermions are physical. What is unphysical is the wave function, since it contains ambiguous information. The physical information sits in the density matrix or the ray defined by the wave function. It's a kind of gauge freedom.
The Plate trick demonstrates this nicely: It's not really just a rotation. It is also an up/down movement that takes place at the same time. The plate itself returns to its original state after a 360° rotation. It's just that the additional up/down degree of freedrom returns only after two periods. The relation to quantum mechanics is: The physical information returns to its initial state after a 360° rotation, but the additional unphysical phase degree of freedom needs two periods. If you strip off the unphysical degree of freedrom (by computing the density matrix), you get an object that only needs a 360° degree rotation to get back to its initial state. Of course in case of the plate trick, the up/down movement isn't unphysical, but then again the whole movement is not just a rotation. In QM, ##SU(2)## is of course not the rotation group, but if you apply the covering map to any ##SU(2)## matrix, you extract the part of the ##SU(2)## transformation that can be considered a rotation.
That's the point of the spin superselection rule! There cannot be superpositions of half-integer and integer-spin kets since all a ##2 \pi## rotation is allowed to do is to multiply all physical states with a common phase factor. Relative phases between components of one state must not occur, because then you'd have observable consequences in terms of interference effects.
No such luck. (Although, perhaps this part of the discussion should be split off into another thread asap? Mentors?)
But all cases of active physical rotation could be seen this way. I have 2 coffee cups on my desk. I reach out with my hand and rotate one of them. That could be expressed as applying time evolution with a different Hamiltonian to one of the cups.
Sure, the particles don't have coordinate systems, but they have an intrinsic orientation property (in general). Applying time evolution with a Hamiltonian involving a magnetic field that changes a particle's orientation certainly counts as "rotating the particle".
Stern-Gerlach is a bit different -- it just applies different linear force dependent on the particle's spin, yielding a spin-dependent final momentum. But there are other configurations of magnetic field which can alter a particle's orientation.
But in the case of fermions, you are not just rotating them. You are also messing with their spin degrees of freedom at the same time. Just like with the Plate trick, the orientation of the system (what does that even mean for a point particle?) comes back after 360°, but since there is an additional degree of freedom (up/down, spin), you can arrange for a return only after 720°. However, you can also rotate the system by chosing a different path through ##SU(2)##, which doesn't mess with the spin degrees of freedom (or messes with them in a different way) and comes back to the original state after 360°.
(Edit: I have thougth about the last sentence a bit more and it probably won't work with just one axis. However, the point is still that a ##SU(2)## transformation is not just a rotation and the orientation still comes back after 360°.)
I wouldn't say that point particles have an orientation, but for the sake of the argument, we could speak of extended objects like atomic nuclei. As I said above, the orientation itself comes back after 360°. It's the additional change in the spin degrees of freedom that allows for the relative phase shift after a 360° rotation.
I don't understand the point about half-integer and integer-spin kets. I'm only talking about a single electron, so it's only half-integer kets involved.
Then all vectors get the same factor ##(-1)## under a ##2 \pi## rotation since the total angular momentum is always half-integer (##1/2,3/2,\ldots##), and there's no problem since overall phases are not observable.
I'm talking about a single electron that can take two different paths. One path causes the electron to rotate 360 degrees. The other path causes no rotation. The paths have the same starting point and the same ending point. So the probability of the electron reaching the ending point depends on interference between the two paths.
I don't understand how you want to achieve this. Do you have something in mind like the Aharonov-Bohm effect? That has nothing to do with what we are discussing about the representation of rotations but is a physical, i.e., observable effect of a non-integrable phase factor.
