Does the Raising Operator Have Right Eigenvectors?
7 replies · 2K views
Pouyan
show that the raising operator at has no right eigenvectors
We know at|n> = √(n+1)|n+1>
we define a vector |Ψ> = ∑cn|n> (for n=0 to ∞)
at|Ψ>=at∑cn|n>=∑cn(√n+1)|n+1>
But further I give up!:cry:
You have to try. It's not that hard.
Well I do see this :
In a solution i do see:
Latex code : \sum_{n=0}^{\infty}c_{n}|n>=\sum_{n=1}^{\infty}c_{n-1}\sqrt{n}|n>
I know how to iterate a sum serie but why shall we say so ?!
and the only possible value is c_n=0
Two things.
1) You should be writing down what it means for ##a^t## to have an eigenvector:
##a^t|\Psi \rangle = \lambda |\Psi \rangle##
2) Sometimes you can see things better using the ##\sum## notation. And sometimes you can see things better with the terms written out. If you are stuck, you should always try both ways. In this case, for example, let:
##|\Psi \rangle = c_0 |0 \rangle + c_1 |1 \rangle + c_2 |2 \rangle \dots ##
You are right that you can show that ##c_n = 0##. Can you show this fully? Also, what about the case where ##\lambda = 0## as a possible eigenvalue?
PeroK said:
Two things.
this is my problem, I don't get it
How can I show
is right if and only if c_n = 0...?
I know the only solution for all n must be c_n=0
How can I show View attachment 231005
You haven't followed either of my suggestions. You must at least write down what it means to have an eigenvector. Maths doesn't solve itself. You need to start working with the equations.
Anyway, the rules of PF are clear: you must start to show some of your work.
$$\sum_{n=0}^{\infty}c_{n}|n\rangle=\sum_{n=1}^{\infty}c_{n-1}\sqrt{n}|n\rangle$$
You might be getting confused because that's wrong. What it should say is
$$\hat a^\dagger \sum_{n=0}^{\infty}c_{n}|n\rangle=\sum_{n=0}^{\infty}c_{n}\sqrt{n+1}|n+1\rangle = \sum_{n=1}^{\infty}c_{n-1}\sqrt{n}|n\rangle.$$ From this alone, you can't conclude anything about the coefficients. You need to use the eigenvector equation @PeroK mentioned above.
The equations given by @PeroK and @vela imply a certain recurrance relationship on your coefficients, i.e.
if ##c_1=1## then ##c_2=\dots## then etc..
Try to write it out, and see what it implies, bearing in mind that one usually wants eigenvectors that can be normalized
