Does U-Substitution Function as the Inverse of the Chain Rule?
  • Context: High School
  • Thread starter Thread starter NoahsArk
    Derivative Integration
The discussion centers around the concept of u-substitution in integration, particularly its relationship to the chain rule. Participants explore examples of u-substitution, its purpose, and how it may be viewed as the inverse of the chain rule. The scope includes theoretical understanding and practical application of integration techniques.
  • Some participants express confusion about the purpose of u-substitution and how it relates to the chain rule in integration.
  • Examples of u-substitution are provided, such as integrating $$\int x(x^2 + 3)^3 ~dx$$ and $$\int \sin{x} \cos{x} ~dx$$, illustrating the technique.
  • One participant elaborates on how u-substitution can be seen as the inverse of the chain rule, providing a formal proof involving the Fundamental Theorem of Calculus.
  • There are concerns about potential misinterpretations of expressions resulting from u-substitution, highlighting the importance of notation clarity.
Participants generally agree on the utility of u-substitution and its connection to the chain rule, but there remains uncertainty about its conceptual understanding and application. No consensus is reached on the clarity of notation or the best way to explain the technique.
Some participants reference previous discussions on related topics, indicating a broader context of inquiry into integration techniques and their foundations.
NoahsArk
TL;DR
I don't get it.
Can someone please give as simple an example as possible to show what U substitution is about? I know basic integration rules but don't understand the point of u-substitution. I've read that it's used to "undo the chain rule", but I don't see how, and don't see how we can spot when we'd need to reverse the chain rule for integration as opposed to just following the normal rule for integration ( adding one to the exponent and dividing by the exponent plus 1). Thanks
NoahsArk said:
TL;DR Summary: I don't get it.
I thought we went through all this in a thread some time ago?
@PeroK I remember asking about the chain rule and implicit differentiation, but not about u substitution. If I did ask about it and you have a link to the prior discussion, please paste it. Thanks
Here's an example that is similar to a question that was recently asked.
You could of course multiply out the square term to get a 7th degree polynomial, but using ordinary substitution is more efficient.
Using the substitution ##u = x^2 + 3## from which we get ##du = 2xdx##, we can rewrite the integral as ##\int u^3 \frac 1 2 du = \frac 1 2 \int u^3 du##. You can then use the power rule for integrals to evaluate the revised integral. Once the integration is performed, undo the substitution.
Another example is:
$$ I = \int \sin{x} cos{x} dx $$
It's not obvious how to do this. But if I set $$ u = \sin{x}, du = \cos{x} dx $$, then we have:
$$ I = \int u du = 1/2 u^2 = 1/2 \sin^2{x} $$
phyzguy said:
then we have: $$ I = \int u du = 1/2 u^2 = 1/2 \sin^2{x} $$
Although the above is correct, some might (incorrectly) interpret the last two expressions as ##\frac 1 {2u^2}## and ##\frac 1 {2\sin^2(x)}##.
These are less prone to misinterpretation as ##\frac {u^2}2## and ##\frac{\sin^2(x)}2## or ##\frac 1 2 u^2## and ##\frac 1 2 \sin^2(x)##.
Thank you for the responses.
Elaborating a little more on my example, and how u substitution is basically the inverse of the chain rule. If you have:$$ \frac{d}{dx} \frac{sin^2(x)}{2}$$
Applying the chain rule, you get:
$$ \frac{d}{dx} \frac{sin^2(x)}{2} = \frac{d}{d(sin(x))}\frac{sin^2(x)}{2} \frac{d}{dx} sin(x) = sin(x) cos(x)$$
Do you see how this is really just the inverse of the u substitution we did above?
The change of variables is really the inverse of the chain rule. Formally, if ##f## and ##u## are suitable functions:
$$\int_a^bf(u(x))u'(x) \ dx = \int_{u(a)}^{u(b)}f(t) \ dt$$The proof is relatively simple:
Let ##F(y) = \int_0^y f(t)dt##. By the FTC (Fundamental Theorem of Calculus), ##F'(y) = f(y)##.
Let ##g(x) = F(u(x))##. By the chain rule: ##g'(x) = F'(u(x))u'(x) = f(u(x))u'(x)##.
Hence:
$$\int_a^bf(u(x))u'(x) \ dx = \int_a^bg'(x) \ dx = g(b) - g(a) = F(u(b)) - F(u(a))$$$$ = \int_{0}^{u(b)}f(t) \ dt - \int_{0}^{u(a)}f(t) \ dt = \int_{u(a)}^{u(b)}f(t) \ dt$$
