Domain and range of composite functions?
To determine the domain and range of the composite function f(g(x)), start by identifying the domain of g(x), as x must be within this range. Next, ensure that the outputs of g(x) fall within the domain of f. The domain of f(g(x)) is thus equivalent to the domain of g(x). For the range, evaluate the outputs of f based on the range of g; if f outputs only positive values, the range of f(g(x)) will be the set of positive real numbers. Understanding these relationships is crucial for accurately determining the domain and range of composite functions.
CAH
hey!
How do you work out the domain and range of fg(x), do you work out what range of g(x) will fit the domain of f(x)?
I have no clue.
Thanks
Mathematics news on Phys.org
Hey CAH,
Sorry, but do you mean f(g(x)) or f(x) * g(x) ?
Based on the thread title, by fg(x) you mean f(g(x)). So you are trying to work out the domain and range for the composition of f with g.
For the range, you would start with the range of the inner function -- g in this case. Figure out what outputs are possible from f when its inputs are in that range.
For the domain, you would start with the domain of the outer function -- f in this case. Figure out what inputs to g can produce outputs in that range.
for example:
f(x)=3e^(2x) domain:(-infinity, +infinity)
g(x)=ln(4x) domain:(0, +infinity)
how would i go about finding the domain and range of f(g(x))?
(thanks for the reply)
First, to be in the domain of f(g(x)), x must first be in the domain of g. Then it must be true that g(x), for that particular x, is in the domain of f. Here, the domain of f is all real numbers so the domain of f(g(x)) is just the domain of g. As for range, g(x) can give any real number but f of any number is positive so the range of f(g(x)) is the set of positive real numbers.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
