Don't Ever Mention "Centrifugal Force" to Physicists
121 replies · 11K views
Argonaut
I've just come across the following line while studying (Young & Freedman) and found it amusing.
It sounds like a dirty family secret we discuss once and then should never mention again :biggrin:
  • Haha
And besides we all take delight in our secret perversions....
It actually can be very useful and I confess to uttering those particular profane words on multiple occasions.
  • Haha
A research scientist at Cambridge suggested the term "centripugal", that being a little less open to misinterpretation than "centrifetal".
I find "radial" forces less provocative of a hostile response.
Centrifugal force is like chainsaw. In the hands of an expert it can be quite useful; in the hands of novice it can do a lot of damage. Young & Freedman are trying to protect the innocent from themselves, hence the statement.
  • Haha
I like the term "fictitious forces."
I did not like it the first time I heard it, but once the idea sunk in it made sense to me.
"In an inertial frame..."
Context is everything. Don't jump to the exciting bits without pondering the qualifiers first.
I have no objection at all to the term centrifugal force. I simply object to its being incorrectly used, which it almost always is when I see it outside of a textbook.
-Dan
What a nonsense. Of course, in an inertial frame of reference there are no inertial forces, but they are very useful to analyze motions in non-inertial frames like, e.g., the reference frames we use everyday in the lab, i.e., a rest frame wrt. a point (our position) on the surface of the Earth. It's almost always enough to neglect the acceleration, but one of the most famous demonstrations of the Earth's rotation around its axis is Foucault's pendulum. There usually the centrifugal part of the inertial forces is, however, neglected (rightfully), but the Coriolis force must be taken into account.
Inertial forces are of course not "real forces" in some sense, i.e., they are not due to the fundamental interactions (gravity, electroweak and strong interactions) but belong to the left-hand side, ##m \vec{a}##, of the equation of motion. Nevertheless it's easier to think of them intuitively as "inertial forces", bringing them on the right-hand side ##\vec{F} \rightarrow \vec{F}+\vec{F}_{\text{inertia}}##.
Some of you have seen this already when a similar discussion flared up and I apologize for the repetition. I resisted at first, but it is worth reviving because it encapsulates the controversy well.
  • Haha
How should we call centrifugal pumps, fans and compressors?
Centripetal fluid accelerator machines?
  • Haha
You either use the terms as they appear in the manufacturer's literature or spend a lot of time explaining to people why they are misnamed. In process technology, pumps move liquids only, and compressors move gasses only. So by that convention a vacuum pump should be called a vacuum compressor. But the manufacturers disagree!
Note that in an inertial frame the rim of the wheel exerts a centripetal force on Mr. Bond. But Mr. Bond exerts a centrifugal force on the rim of the wheel.
But they are not misnamed. The name depends on an equivalent frame of reference in which the working principles are formulated.
@Argonaut played a trick on you all, and he got you real good. Ha ha ha! The joke's on you!
Here is the whole thing in context:
CAUTION Avoid using “centrifugal force” Figure 5.30 shows both a correct free-body diagram for uniform circular motion (Fig. 5.30a) and a common incorrect diagram (Fig. 5.30b). Figure 5.30b is incorrect because it includes an extra outward force of magnitude [itex]v^2/R[/itex] to “keep the body out there” or to “keep it in equilibrium.” There are three reasons not to include such an outward force, usually called centrifugal force (“centrifugal” means “fleeing from the center”). First, the body does not “stay out there”: It is in constant motion around its circular path. Because its velocity is constantly changing in direction, the body accelerates and is not in equilibrium. Second, if there were an additional outward force that balanced the inward force, the net force would be zero and the body would move in a straight line, not a circle (Fig. 5.29). And third, the quantity [itex]m(v^2/R)[/itex] is not a force; it corresponds to the [itex]m\vec{a}[/itex] side of [itex]\sum\vec{F} = m\vec{a}[/itex] and does not appear in [itex]\sum\vec{F}[/itex] (Fig. 5.30a). It’s true that when you ride in a car that goes around a circular path, you tend to slide to the outside of the turn as though there was a “centrifugal force.” But we saw in Section 4.2 that what really happens is that you tend to keep moving in a straight line, and the outer side of the car “runs into” you as the car turns (Fig. 4.11c). In an inertial frame of reference there is no such thing as “centrifugal force.” We won’t mention this term again, and we strongly advise you to avoid using it as well
So, they are not saying there is never utility in inertial forces. They are saying not to misuse the concept, and 10% of the way through a first course of physics is not the place.
Why not just rename the centripetal force as the centrifugal force, the force a centrifuge accelerates an object towards the center of motion?
While we're at it, let's swap the sign on the electron charge so electron flow matches conventional current!
  • Haha
I think that's a very positive suggestion.
Ibix said:
Indeed, and I can't see any negatives either.
Ok, we should put you in charge of the process at the current time.
  • Wow
  • Haha
Why not rename resistance to voltage? Why not rename force to energy?
Why not call everything "Bruce", just to prevent confusion?
  • Haha
I didn't mean to mislead anyone, and if I did, I apologise. I'm probably just too ignorant of physics to even realise. I just found the authors' insistence on avoiding the term funny - that's all!
Excellent idea! That would be the first step towards a one-size-fits-all Theory of Everything. For example,
##\mathbf{Bruce}=Bruce~\mathbf{Bruce}## (Newton's Second Law)
##Bruce=Bruce~Bruce## (Ohm's Law)
##Bruce=Bruce~c^2## (the speed of light is the same in all formulations)
etc. etc.
I stop here lest the thread be closed by the mentors for silliness.
  • Haha
You did fine and, as you can see, people had fun here.
There's more than one concept that students will have heard of but it's better to avoid (at least initially) because they always lead to confusion in novice hands. So you will occasionally come across "I know you know this word and I know you're expecting me to use it but I'm not going to". I suspect it's not an easy thing to use a concept enough to explain why you're not going to use it without using it too much. 😁
It is a radial outward force, but it is not the fictitious force that appears in the rotating non-inertial frame and is generally called “centrifugal”. That fictitious force acts on Bond, not the rim of the wheel.
Just keep in mind that in Italian, "voltae" means to "turn".
A gas compressor compresses a gas. A liquid pump moves a liquid. A vacuum "device" neither compresses nor moves a vacuum. However, it may do both moving oil and compressing gases. So maybe we should just call it a "vacuum maker". Or maybe just Mister Vacuum.
