- 174
@atyy: I don't think that there is a problem with the "causal restriction". This is true if you do ordinary QFT on a given background. But that's not the case; you try to construct the basic building blocks and there is no reason why you should use a building block X and not use a building block Y. Look at ordinary QFT: you just select a few fields (scalar, spinor, vector), write down the PI and check if it works. Of course you made a selection, but in the end nature will tell you if the selection was correct.
I see this issue of "local causal restriction", but I don't think it's an a priory issue for CDT in the narrow sense. What I coul imagine is that it becomes an issue as soon as you put matter on the triangulation and study its propagation.
The concept of causality is tricky in these discrete models and I agree that CDT may be too limited in order to study it properly. Let's focus on LQG (even if we know that according to Lubos it is flawed, too :-)
In LQG (or in general in any approach based on graphs) one has to distinguish between local and global causality. Local causality means that there is a local "nearest neighbor law" which says that during one "clock tick" only connected vertices are dynamically related. In LQG this is satisfied; the Hamiltonian respects such a local causality. But at the same time there could be non-local effects (where locality is now defined with respect to the existing spin network). Let's assume that you have a spin network which is dual to a triangulation; of course it's possible to construct a "non-local" link connecting two vertices which are separated by a huge number of cells (according to the triangulation). This "non-local" link does not violate local causality as long as it is guratantueed that it was created via local interactions. If the Hamiltonian produces such a non-local link connecting two vertices which are separated by 1000 cells during 1000 clock ticks everything is fine. So the existence of such non-local links doesn't automatically imply that there theory is flawed.
Of course there is a further requirement, namely that these non-local links must be dynamically supressed simply b/c we do not observe them in nature! There are no shortcuts from here two the Andromeda galaxy!
That means the theory (even if it allows for non-local links) must produce an emergent global causality which fits to the observed causality on large length scales. The whole concept of light cones doen't exist locally. It emerges at largeer scales and of course it must fit to what we observe in nature. That means that what we call "causality" is "global causality" which emerges from the dynamics of the theory and which is not an ingredient of the theory.
The problem with CDT is that it may be a too narrow framework as it focuses on triangulations which can only be defined using an underlying concept of a manifold (of which are at least not independent from these concept). In CDT one cannot study non-local links; they simply do not exist. Every triangulation is topologically a three-space whereas in LQG based on spi networks it cannot even be guarantueed that the graph is dual to a 3-dim. triangulation. So in LQG (or in any other theory based on graphs) the consistency check is not so much that the resulting long-range geometry is Minkowski or something like that, the check is if the long-range limit is a 3-geometry at all!
My conclusion is that CDT is only a restricted calculational tool which sits somehow in between of the concept of smooth 3-manifolds and an underlying discrete structure. That does not mean that CDT is wrong, it only means that CDT does not provide a deeper understanding of conceptual issues. Look at QCD and the non-relativistic quark model (based on constituent quarks). Of course this model is "wrong" in some sense, but in a certain regime it generates reasonable results. It serves as a calculational tool which incorporates some principles from full QCD (color, flavor) but which has somehow "integrated out" current quarks and gluons. In that sense CDT uses a ceratin concept of causality w/o explaining the emergence of this principle.
