Doppler effect and beat frequency
The discussion focuses on the Doppler effect and beat frequency involving two speakers, A and B, and a listener, L. The listener hears beats with a frequency of 6 Hz when stationary, indicating a frequency difference between the speakers. When the listener moves towards speaker B at 5 m/s, the frequencies equalize, resulting in no beats. The calculated frequency of speaker A is 207 Hz, while the required speed of speaker B to avoid beats is determined to be -9.8 m/s, indicating it must move towards the listener.
  • Doppler effect principles
  • Beat frequency calculation
  • Wave frequency and speed relationships
  • Basic algebra for solving equations
  • Study the mathematical derivation of the Doppler effect
  • Explore beat frequency applications in acoustics
  • Learn about sound wave propagation in different media
  • Investigate advanced topics in wave interference
Students of physics, acoustics researchers, and anyone interested in understanding sound wave behavior and frequency interactions.
Kolika28
Summary:: Two speakers A and B are at rest, and a listener L stays on the line that connects the two speakers (see picture). The speakers have almost the same frequency. Assume that the speed of sound in air is 340 m/s. When the listener is at rest, he/she hears beats with frequency 6 Hz. The listener is moving towards speaker B with a constant speed of 5 m/s, he/she hears no beat (same frequency from both speakers).
a) What is the frequency of speaker A?
Now the listener is at rest, but the speaker B moves at a constant speed in the same direction that connects A and L. Speed is positive to the right (see the figure), otherwise it is negative.
b) What is the speed of the sound source B (m/s) so that the listener does not hear beats?
a) So ##f_beat=abs(f_A-f_B)=6##. Since the listener does not here at beat when moving toward B ##f_A=f_B## here. Then I use the formula for doppler effect:
##f_L=\frac{340 m/s -5 m/s}{340 m/s}*f_A## (1) and ##f_L=\frac{340 m/s+5 m/s}{340}*f_B## (2). I use the fact that ##f_B=f_A-6## and set the equations 1 and 2 equal each other and get that ##f_A=207 Hz##.
b) I don't get the right answer for this problem. I do almost the same like I did in a) :
##f_L=\frac{340 m/s+0}{340 m/s+0}*207 Hz## and ##f_L=\frac{340 m/s+0}{340 m/s +v_B}*(207-6)Hz## and I get that ##v_B=9.8 m/s##. But this is not correct according to my teacher. Does anyone have some tips?
Ohh, I see now? Can it be that I forgot a minus sign in the answer?
Certainly the solution to your equation is negative, and the answer should be negative since B has the lower frequency, and will have to move left to sound as high.
Thank you for your help! :smile:
  • · Replies 19 ·
  • · Replies 33 ·
