Doppler Effect of a Laser Reflected from a Moving Mirror
The discussion focuses on the Doppler Effect as it pertains to a laser beam reflected from a moving mirror. The key equation used is f_{1} = f_{0} / (1 + v/c), where f_{0} is the frequency of the source and f_{1} is the frequency of the incident light as measured by the moving mirror. The conversation highlights the relationship between frequency and wavelength, clarifying that the approximation λ' / λ = 1 - v/c is commonly used when the speed of the mirror (v) is much less than the speed of light (c). Participants confirm the validity of these equations and their derivations.
  • Understanding of the Doppler Effect in physics
  • Familiarity with wave frequency and wavelength relationships
  • Basic knowledge of light behavior and reflection
  • Concept of relative motion in physics
  • Study the derivation of the Doppler Effect equations in detail
  • Explore the implications of the approximation λ' / λ = 1 - v/c
  • Investigate applications of the Doppler Effect in real-world scenarios
  • Learn about the behavior of light in different mediums and conditions
Students of physics, educators teaching wave mechanics, and anyone interested in the practical applications of the Doppler Effect in optics and sound.
GreenPrint
A laser emits a monchromic beam of wavelength λ, which is reflected normally from a plane mirror, receding at a speed v. What is the beat frequency between the incident and reflected light?
The solutions starts off with this
f_{1} = \frac{f_{0}}{1 + \frac{v}{c}}
But I'm not exactly sure where this equation came from. The solution uses
f_{0} frequency of source
f_{1} frequency of incident light (source) as measured by moving mirror
f_{2} frequency of reflected light as measured by the moving mirror
I know that the Doppler effect is often stated as
\frac{λ^{'}}{λ} = \sqrt{\frac{1 - \frac{v}{c}}{1 + \frac{v}{c}}}
So I'm not exactly sure where the first equation came from. Thanks for any help.
Are you sure about your equation? In my book it is the same, but without the square root.
If you replace the wavelengths by the frequency and isolate for f1, you will get the equation, they start off with.
Remember that the two velocities are of the observer and reciever. So one of them is zero. The top velocity in your bracket, that is.
The lower velocity is positive, when the mirror moves away from a stationary source. So you get, what they have.
Ya. I just read underneath that part and it says that when v << c Eq. (4-44) (the equation I posted in the first post for the Doppler Effect) is approximated by
\frac{λ^{'}}{λ} = 1 - \frac{v}{c}
Which I didn't realize. I remember reading it earlier but it left my mind because I would rather use the equation in post one. It's interesting that your book doesn't mention it being a approximation, but that is probably because v << c occurs a lot.
Thanks for the help.
Wait hold on. What allows us to simply replace the wavelengths with the frequencies and just interchange them? I thought that the equation applied to wavelengths. Oh ok I know why lol.
Yeah, well the "approximation" is the most commonly used equation, which probably explains it. Anyway, all equations are based on approximations to a certain degree :-)
  • · Replies 16 ·
