Double checking needed on 2 Differential Equations
The discussion revolves around two differential equations. The first equation involves finding a solution using power series methods, while the second equation requires the application of Euler's method for solving. Participants are verifying the correctness of their approaches and solutions.
  • Mixed
  • The original poster attempts to derive a recursion formula for the first differential equation and expresses concern about the correctness of their final answer. For the second equation, they explore the use of the quadratic formula to find roots and present a general solution. Some participants affirm the solutions, while others express interest in the tools used for verification.
Some participants have confirmed the correctness of the original poster's solutions, indicating a productive exchange. There is also a suggestion regarding accessing software that could assist in future problem-solving.
Participants discuss the potential availability of software licenses through their college, which may influence their ability to utilize certain computational tools.
VinnyCee
Problem 1:
Find solution for:
(x^2\,-\,4)\,y''\,+\,(3\,x)\,y'\,+\,y\,=\,0
using power series methods.
Answer 1:
I get a recursion formula:
a_{n\,+\,2}\,=\,\frac{n\,+\,1}{4\,(n\,+\,2)}\,a_n
and a final answer:
y(x)\,=\,a_0\,\left[1\,+\,\frac{x^2}{8}\,+\,\frac{3}{128}\,x^4\,+\,\frac{5}{1024}\,x^6\,+\,...\right]\,+\,a_1\,\left[x\,+\,\frac{x^3}{6}\,+\,\frac{x^5}{30}\,+\,\frac{x^7}{140}\,+\,...\right]
Does that look right?
Problem 2:
Use Euler's method to solve:
(2\,x^2)\,y''\,+\,(x)\,y'\,+\,y\,=\,0
Answer 2:
Using the quadratic equation to solve for r:
2\,r^2\,-\,r\,+\,1\,=\,0
r\,=\,\frac{1}{4}\,\pm\,\frac{\sqrt{7}}{4}\,i
Which means that:
\lambda\,=\,\frac{1}{4} AND \mu\,=\,\frac{\sqrt{7}}{4}
And finally:
y(x)\,=\,C_1\,x^{\frac{1}{4}}\,cos\,(\frac{\sqrt{7}}{4}\,ln\,x)\,+\,C_2\,x^{\frac{1}{4}}\,sin\,(\frac{\sqrt{7}}{4}\,ln\,x)
Thanks for the checking in advance!
Mathematica agrees with both of your solutions. Well done.
--J
Thanks a lot
I need to get that program someday!
It's possible that your college has a license for it and will give it to you. Why don't you contact your IT department and ask?
--J
  • · Replies 18 ·
  • · Replies 16 ·
