Volume Calculation Using Cylindrical Shells for Functions in First Quadrant
  • Thread starter Thread starter Jbreezy
    Volume
The discussion focuses on calculating the volume generated by rotating the region between the functions f(x) = x^2 and g(x) = 2x in the first quadrant about the y-axis using cylindrical shells. The integral set up is V = 2∏∫x(2x - x^2) dx from 0 to 2, leading to a calculated volume of 8∏/3. The poster seeks confirmation on the correctness of their integral and solution before submission. Responses indicate that the setup and calculations appear accurate. The final volume calculation is confirmed as correct.
Jbreezy
Consider the region between the functions f(x) = x^2 and g(x) = 2x in the first quadrant.
Use the method of cylindrical shells to find the volume generated by rotating about the y axis.
I did this integral
V = 2∏∫x(2x-x^2) dx between [0,2]
I got 2∏((2/3)x^3 - (x^4/4) = 8∏/3
I think it is OK just want someone to confirm. Before I turn in.
Looks fine to me.
Thanks amigo.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
