Double integral of gaussian times mod cos function
The discussion revolves around evaluating a double integral involving a Gaussian function multiplied by the absolute value of a cosine function. The integral is defined over the entire xy-plane and includes constants that affect its evaluation. Participants are exploring the complexities introduced by the absolute value in the cosine function and its implications for solving the integral.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss changing variables to simplify the integral, with one suggesting a transformation to express the integral in terms of a new variable. There are questions about the treatment of constants during integration and the implications of the absolute value on the cosine function. Some participants express uncertainty about how to proceed with the integration after the variable change.
The discussion is ongoing, with participants providing insights into potential approaches and clarifying misunderstandings. There is a focus on ensuring the correct application of mathematical principles, particularly regarding variable substitution and the treatment of constants. No consensus has been reached on a definitive method for solving the integral, but several lines of reasoning are being explored.
Participants are working under the constraints of a homework problem, which may limit the information available for solving the integral. The presence of the absolute value in the cosine function is a significant point of contention, affecting the approaches being considered.
Idoubt
I want to evaluate the following definite integral of the form,
[tex]I = \int\limits_{x = -\infty}^{\infty}\int\limits_{y = -\infty}^{\infty} e^{-ax^2} e^{-by^2} | \cos(c x + d y)| dx dy[/tex]
where a, b, c, and d are constants, as part of a larger problem I am doing,
[tex]\cos x = \frac{1}{2} ( e^{ix} + e^{-ix})[/tex]
[tex]\int\limits_{-\infty}^{\infty} e^{-a(x - b)^2} dx= \sqrt{\frac{\pi}{a}}[/tex]
If it wasn't for the abs value on the cos function it would be easy to write it in terms of exponentials and complete squares and perform the integral. As it is I don't know how to approach this, any help would be great. I have given a general form of the integral but for my purpose it's ok to assume a =b.
If you change variables to ##cx+dy = z\; \Rightarrow \; y = pz - qx## your integral becomes
$$I = \int_{x=-\infty}^{\infty} \int_{z = -\infty}^{\infty} p\, e^{-ax^2 - b(pz-qx)^2} |\cos(z)| \, dx \, dz$$
For fixed ##z## you can do the ##x##-integral first, and so end up with
$$I = A \int_{-\infty}^{\infty} e^{-r z^2} |\cos(z)| \, dz,$$
where
$$A =p \frac{\sqrt{\pi}}{\sqrt{a+bq^2}} \: \text{and} \; r = \frac{a b p^2}{a+bq^2}$$
You can go a bit farther, by writing
$$\begin{array}{l} I = A \int_{-\infty}^{\infty} e^{-r z^2} \cos(z) \, dz\\
- 2A\left[ \int_{-3\pi/2}^{-\pi/2} + \int_{\pi/2}^{3\pi/2} + \int_{-7\pi/2}^{-5\pi/2} + \int_{5\pi/2}^{7\pi/2} + \int_{-11\pi/2}^{-9\pi/2} +\int_{9\pi/2}^{11\pi/2} + \cdots \right] \,e^{-rz^2} \cos(z) \, dz,
\end{array}$$
That comes from adding to the simple "cos" integral, twice the sum of those "cos" integrals where ##\cos(z) < 0## and noting that these latter cover the intervals ##(-3\pi/2,-\pi/2), (\pi/2 , 3\pi/2)## and the intervals ##(\pi/2 + 2 \pi n, 3\pi/2 +2 \pi n), (-3\pi/2 - 2 \pi n, -\pi/2 - 2 \pi n)## for ##n =1,2,\ldots ##.
At that point I cannot see how to give a more useful answer, although the integrals can be done in terms or error functions of complex arguments that depend on r and n, but I don't see that as very helpful. The expression might well be amenable to numerical evaluation, since the presence of factors ##e^{-4 \pi^2 r n^2}## means that good accuracy ought to be attainable from a few small values of ##n = 0, \pm1, \pm2, \ldots## and then the individual integrals can be tackled numerically.
Ray Vickson said:
If you change variables to ##cx+dy = z\; \Rightarrow \; y = pz - q## your integral becomes
$$I = \int_{x=-\infty}^{\infty} \int_{z = -\infty}^{\infty} p\, e^{-ax^2 - b(pz-qy)^2} |\cos(z)| \, dx \, dz$$
where
Thank you for the reply. I have a doubt though. If you change variables such that ## cx + dy = z \Rightarrow y = \frac{z}{d} - \frac{cx}{d} \equiv pz - q, ## where ## q(x) = \frac{cx}{d} ## how can you do the x integral? Do you mean complete squares in the x variable and then inegrate? But then there shouldn't be any q after integration right? But it looks like q is being treated as a constant.
I made a typo when I wrote ##e^{-ax^2-b(pz-qy)^2} \,dx##; it should have been ##e^{-ax^2-b(pz-qx)^2} \,dx##, because ##y = pz - qx##; and, of course, ##p=1/d## and ##q=c/d## really are constants. The ##x##-integral will be of the form ##\int_R e^{-Ax^2-Bx-C} \, dx## with constants ##A,B,C## (which may contain the un-integrated variable ##z##). Certainly the answer will be in terms of ##A,B,C##.
The formulas I wrote later are correct; I did them on the computer algebra system Maple, using correct formulas without any typos in the inputs. You should never, never just copy down such things, but should yourself carry through all the steps to see what you get.
Typos fixed in original.
  • · Replies 19 ·
