How do I evaluate a double integral over a specific region?
To evaluate the double integral over the specified region R, it is crucial to first sketch the region defined by the inequalities y ≤ x ≤ 1 and 0 ≤ y ≤ 1. The discussion emphasizes the importance of choosing the order of integration, suggesting that integrating with respect to y first may simplify the process. Participants clarify that integrating over y will eliminate y from the integral, allowing for a clearer path to the solution. A visual representation of the region can aid in correctly setting up the limits of integration. The final approach depends on the chosen order of integration, which can be either dy first or dx first.
kieranl
Sketch the region of integration and then evaluate the double integral:
\int\intx2exydA over the region R= {(x,y), y<=x<=1, 0<=y<=1}
I have managed to do half of the problem and integrate it respect to x but then have no idea how to finish the problem.
I mangaged to get upto \intey(2/y2-2/y3-1/y)+ey2(y-2/y+2/y3) dy
can someone please tell me how to finish it or if i have done something wrong so far??
cheers
Welcome to PF!
Hi kieranl! Welcome to PF! :smile:
(have a ≤ :wink:)
uhh? :confused:
start again, and integrate over dy first! :smile:
but if i integrated by dy first wouldn't i end up with an answer containing y's and not numbers??
If you integrate with respect to dy, then you eliminate y, and only have x's.
but i have to integrate over y<=x<=1 for dx so the final answer would then contain y's?
Draw a picture of the region R. Then use the picture to write R in the form
R={(x,y):a<x<b, f(x)<y<g(x)}.
Hi kieranl! :smile:
(have an integral: ∫ and a ≤ :wink:)
No, you have to integrate over 0 ≤ y ≤ x ≤ 1 …
whether you do it over x first or over y first is up to you. :wink:
  • · Replies 19 ·
  • · Replies 17 ·
