Double Integrals for Volume in the First Octant: Iterated Integral Methods
  • Thread starter Thread starter RaoulDuke
    Integrals
RaoulDuke
Set up the following as a double integral whose value is the stated volume, express this double in two ways as an iterated integral, and evaluate one of these.
Volume, in the first octant, bounded by -
z = 4- (y^2)
x=0
y=0
z=0
3x + 4y =12
Forgive me if I don't know my way completely around conveying the notation online.
y = (12 - 3x)/4
When y = 0, x = 4.
x = (12-4y)/3
when x = 0, y = 3.
I assume that I set up the integral in two ways, one where dA = dy dx and another where dA = dx dy.
[tex]\int[/tex][tex]^{4}_{0}[/tex] [tex]\int^{(12-3x)/4}_{0}[/tex] (4 - y[tex]^{2}[/tex]) dy dx
or
[tex]\int[/tex][tex]^{3}_{0}[/tex] [tex]\int^{(12-4y)/3}_{0}[/tex] (4 - y[tex]^{2}[/tex]) dx dy
and solve? Basically, did I set up the integrals correctly?
First I'll fix up your LaTeX, and will then take another look a little later. What you did is not too bad, so kudos for getting as much of it right as you did. Tip: use only one pair of [ tex] [ /tex] tags, with everything inside the single pair. That works better than having a whole multitude of tex tags. You can click the integral to see what I did.
z = 4- (y^2)
x=0
y=0
z=0
3x + 4y =12
y = (12 - 3x)/4
When y = 0, x = 4.
x = (12-4y)/3
when x = 0, y = 3.
[tex]\int^{4}_{0}\int^{(12-3x)/4}_{0} (4 - y^{2}) dy dx[/tex]
or
[tex]\int^{3}_{0} \int^{(12-4y)/3}_{0} (4 - y^{2}) dx dy[/tex]
The second integral is close, but the first one is off by a lot, since two separate integrals are required and you have only one.
Setting up these integrals and changing from one order of integration to another requires a good understanding of the two-dimensional region over which integration takes place. Your mistake is in thinking the the region of integration is a triangle. It isn't; it's a trapezoid in the x-y plane bounded by the origin, and the points (4, 0, 0), (0, 2, 0), and the intersection point in the x-y plane of the plane 3x + 4y = 12 and the cylinder z = 4 - y^2. I didn't calculate its exact position, but it looks to be at about (1, 2, 0).
If you have strips that are parallel to the x-axis, the individual strips run from x = 0 to x = 4 - (4/3)y, and these strips sweep across from y = 0 to y = 2. One integral suffices.
If your strips are parallel to the y-axis, some of the strips run from y = 0 to y = 2, but the others run from y = 0 to y = 3 - (3/4)x. Since the strips have different bounds, you need two different integrals when you integrate first with respect to y then with respect to x.
