Double pendulum equations of motion using Newton's laws
8 replies · 8K views · last reply
BayMax
equations of motion
angular momentum equation
I need help to understand this problem taken from Mechanical Vibrations by S. Rao
Diagram of a double pendulum hanging from a ceiling support, with mass m1 on the first rod (length l1, angle θ1) and mass m2 on the second rod (length l2, angle θ2), with displacement coordinates x1, x2 and y1 marked.
Handwritten derivation of double pendulum equations of motion, taking moments about O and mass m1, ending with equations E1 to E5 in terms of x1 and x2 and a labelled diagram of the pendulum.
I know that the equations of motion could be obtained in various ways, for example using the Lagrangian, but, at the moment, I am interested in understanding the method he used. In particular, if I'm not mistaken, he used moments equilibrium about point O and point ##m_1##. Here's my questions:
1- Why in the moments equilibrium about the point O (equation E1) he considered only the forces acting on ##m_1## as if ##m_2## were not there and also just the moment of inertia of ##m_1##?
2- But above all, in the equation E2, where does the highlighted term ##m_2⋅l_2(l_1⋅\ddot\theta_1)## come from and what does it represent?
3- I have a lot of problems when I'm asked to find equations of motion of a system of particles (like in this case) or of a rigid body, so I need some good resources (textbooks preferably) where I can find all the tools I need to understand and solve this kind of problems.
Thanks !
Welcome to PF!
Equation E1 comes from ##\sum \tau = I \alpha## applied to just ##m_1##. So, ##I## is the moment of inertia of just ##m_1##.
The effect of ##m_2## on ##m_1## is via the tension force ##Q## in the lower rod.
Equation E2 can be derived from ##\sum \tau = I \alpha## applied to ##m_2## and taking the origin for moments to be the instantaneous location of ##m_1##. But, the frame attached to ##m_1## is an accelerating frame. So, there will be a fictitious force acting on ##m_2## that contributes to the moments acting on ##m_2##.
In the lab frame, the acceleration of ##m_1## can be decomposed into a tangential and a radial component:
Diagram of a double pendulum: first rod l1 hangs from a ceiling at angle θ1 to the vertical with bob m1, second rod l2 at angle θ2 with bob m2, horizontal offsets x1 and x2 and height y1 marked, and a red arrow with blue component arrows at m1.
In the frame of ##m_1##, we must add a body force of ##-m_2\vec{a}_1## to the particle ##m_2##, whose components look like negated multiples of the components of the acceleration,
Diagram of a double pendulum hanging from a hatched ceiling support, with lengths l1 and l2, angles θ1 and θ2 from vertical, masses m1 and m2, and horizontal displacements x1 and x2 and height y1 labelled. Blue and red force vectors are drawn at m2.
Note that the blue components are parallel and perpendicular to ##\vec{l}_1##, not ##\vec{l}_2##. So the total force on ##m_2## in the non-inertial rest frame of ##m_1## is the weight, plus the tension, plus this inertial force.
In the small amplitude regime, the we approximate for the purposes of computing the torque of the inertial force that ##\vec{l}_1 \parallel \vec{l}_2##, and as such the component of torque due to this inertial force out of the paper is ##m_2 l_2 (l_1 \ddot{\theta_1})##.
Thank you so much !
I was going crazy in trying to understand this solution. Just a last thing about it: among the fictitious forces we can find Coriolis force too, am I right ? In this case we can neglect it because it's directed along ##l_2## so that its moment about ##m_1## is ##0## ?
BayMax said:
Thank you so much !
You don't need to here. We can choose our non-inertial reference frame so that its origin tracks the position of ##m_1## but its axes are always still aligned with that of the lab frame, so it is an accelerating frame but not a rotating frame. So we only require the one fictitious force.
Coriolis forces only arise in rotating frames, i.e. then the coordinate axes are themselves rotating w.r.t. some inertial frame. Rotating frames are much more complex, and when you employ them you must make sure to account for centrifugal, Coriolis and Euler forces.
Note that you could, if you really wanted to, define a new reference frame that is both translating and rotating, with the origin still at ##m_1## however the axes aligned parallel and perpendicular to ##\vec{l}_1## always.
Then you would need to account for the whole ensemble of fictitious forces. Note that you would also need to redefine your coordinates, since the angle to the vertical axis in your rotating and translating frame will not be ##\theta_2##!
Got it, thanks a lot !
This choice of our non-inertial reference frame is the smartest one !
And thanks for having answered instantly !
I take this opportunity to ask you if you can suggest me some good resources (preferibly, but not necessarily, textbooks) where i can find all this stuff
No problem :smile:, @TSny's the expert and can probably give you some much better recommendations, but I really like Morin's classical mechanics textbook. It does have quite a good section on accelerating frames, and also quite a lot on rigid body motion.
MIT OpenCourseWare also has some really good mechanics stuff, maybe have a look into that too!
Thanks again !
I'll take it. Unfortunately in my university there's no a specific course about classical/Newtonian mechanics but it's only a part of physics course, even if in higher courses I need it, so I'm trying to delve into the topic.
