Angular Position of 1st Dark Fringe in Two-Slit Interference Pattern?
The discussion focuses on calculating the angular position of the first dark fringe in a two-slit interference pattern created by a blue laser beam with a wavelength of 470nm. The slits are separated by 0.2mm, and the screen is located 2m away. The correct formula for determining the position of dark fringes is dsin(theta) = (n + 1/2)(lambda), where n is the order of the dark fringe. The small angle approximation can be applied in this scenario due to the relatively small angles involved.
  • Understanding of two-slit interference patterns
  • Familiarity with the wave nature of light
  • Knowledge of the small angle approximation
  • Basic trigonometry, specifically sine and tangent functions
  • Research the derivation of the two-slit interference formula for dark fringes
  • Learn about the small angle approximation and its applications in optics
  • Explore the effects of varying slit separation on interference patterns
  • Investigate the impact of wavelength changes on fringe spacing in interference patterns
Students studying optics, physics educators, and anyone interested in understanding interference patterns and their mathematical foundations.
NelielSwann
A blue laser beam of wavelength 470nm (in air) is incident on two narrow slits separated by .2mm and produces an interference pattern on a screen located 2m away from the two slits.
Find the angular position (in degrees) of the 1st dark fringe. Can you use the small angle approximation?
dsin(theta)=n(lambda)
tan(theta)= y/L
I've searched all over for a formula to find the dark fringes, but all i can find is one for the light ones. the dsin(theta)=n(lambda) is used for the maxima. what formula do i use for the minima/dark fringes?
For dark fringes use dsin(theta)=(n + 1/2 )(lambda)
For two-slit interference, the minima are halfway in between the maxima.
