Double Slit, different wavelengths change in X
5 replies · 5K views · last reply
rss14
Two slits are 0.158mm apart. A mixture of red light (wavelength = 665nm) and yellow-green light (wavelength = 565nm) fall onto the slits. A screen is located 2.2m away. Find the distance between the third-order red fringe and the third-order yellow-green fringe.
Since they ask for colored fringes, and not dark ones, it must be constructive interference.
x/L = (m*λ/ d)
x = 0.000158m
L = 2.2m
m = 3 (third order fringe)
λ of red = 6.65E-7m
λ of yellow-green = 5.65E-7m
I did the equation twice, once for each wavelength.
For red I got x as 2.7E-2m, and for yellow-green i got x as 2.36E-2m.
The difference between these 2 values is 0.0034mm or 3.4mm.
The answer however, is supposed to be 28mm. . .
How was I supposed to do this?
Here is another question, similar concept.
Light of wavelengths 480nm and 632nm passes through two slits 0.52mm apart. How far apart are the second-order fringes on a screen 1.6m away?
x for red is slightly off. Can you express the answer with one more decimal place of accuracy? I.e., 2.7_ e-2 m.
You're already in the right ballpark. I disagree with the 28 mm answer, who or what told you that is the answer?
The textbook says that in the back.
Also, the second question I posted has an answer of 7cm, according to the book.
I am going to bump this thread, hopefully my question will be answered before my test tomorrow.
You have the correct approach, but you had some round-off error in the first problem.
Both book answers are wrong. For the 1st question, 28 mm is the displacement of the 665 nm, 3rd-order fringe, not the separation of the two colored fringes.
Not sure where they got 7 cm for the 2nd problem.
Good luck on the test.
