Doubling the energy of an oscillating mass on a spring
The discussion centers on the relationship between amplitude and energy in simple harmonic motion (SHM) of a mass on a spring. Participants confirm that increasing the amplitude by a factor of √2 doubles the total energy, as expressed by the equation Total Energy = ½kA². Additionally, they clarify that increasing angular frequency by √2 also results in doubled energy, leading to the conclusion that both options A and B are correct in the context of the problem. The conversation highlights the importance of understanding the distinction between circular motion and one-dimensional oscillations.
  • Understanding of simple harmonic motion (SHM)
  • Familiarity with energy conservation principles in physics
  • Knowledge of angular frequency and its calculation: ω = √(k/m)
  • Basic grasp of kinetic energy equations in oscillatory systems
  • Study the derivation of energy equations in simple harmonic motion
  • Learn about the differences between one-dimensional and two-dimensional oscillations
  • Explore the implications of angular frequency in various oscillatory systems
  • Investigate the role of amplitude in energy calculations for SHM
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators seeking to clarify concepts related to energy in simple harmonic motion.
Turion
Attached.
From my calculations, option A is correct. What am I doing wrong? Also, I can't find a relationship between amplitude and energy.
{ KE }_{ max }=\frac { 1 }{ 2 } m{ { v }_{ max } }^{ 2 }\\ =\frac { 1 }{ 2 } m{ (rω) }^{ 2 }\\ =\frac { 1 }{ 2 } mr^{ 2 }{ ω }^{ 2 }\\ { { KE }'_{ max } }=\frac { 1 }{ 2 } mr^{ 2 }{ (\sqrt { 2 } ω })^{ 2 }\\ =m{ r }^{ 2 }{ ω }^{ 2 }\\ =2{ KE }_{ max }
By conservation of mechanical energy during SHM,
KE + PE = constant.
Total energy = constant = ½kA2
Where A is the amplitude, so option A should be correct.
KE + PE = constant.
Option A doesn't involve amplitudes though. You mean option B?
Okay, I understand now how I increasing the amplitude by √2 doubles total energy. However, it seems that increasing angular frequency by √2 also doubles total energy, so are both option A and option B correct?
yep. Nice work!
Edit: is the mark scheme saying that only B is correct? as you said, it looks like A and B are both true.
Arghh... I'm not sure how my physics professor missed that. Now I'm a little nervous that she might mark my correct answers as wrong for the final tomorrow.
Thanks for the help! :)
I meant option B, sorry.
In your equations, you used v=rω which is for circular motion. Your motion happens to be a mass oscillation.
Oh, I see. This is my fault for plugging and chugging. I have to understand what the equations mean.
So I can only use v=rω for circular motion (i.e. two-dimensional oscillations) only? It doesn't apply to one-dimensional oscillations?
still, even for mass oscillation, the 'angular frequency' is defined by the equation:
\omega = \sqrt{\frac{k}{m}}
Even though it is not related to a circular motion. So I think A and B should both be correct.
Edit: but yeah, as rockfreak says, it is not circular motion, so the calculation should be a bit different.
yeah. After all, the velocity in one-dimensional SHM should be varying, right?
Yes, it does vary. But what does that have to do with it?
30 seconds of thinking...
Oh wow! Brilliant!
So the equation v=rω makes use of the fact that the magnitude of velocity in circular motion stays constant!
yes, for uniform circular motion.
edit: I mean yes, for uniform circular motion the magnitude of velocity is constant, so the angular frequency is constant. (i.e. a parameter of the system).
  • · Replies 21 ·
  • · Replies 24 ·
  • · Replies 20 ·
