Doubt in semiconductor diode theory ?
The discussion revolves around the theory of semiconductor diodes, specifically focusing on the behavior of electrons and holes in a forward-biased diode. Participants explore the mechanisms of current flow and the roles of electrons and holes in this context.
  • Conceptual clarification, Technical explanation
  • One participant expresses confusion about how current can flow if both electrons and holes recombine and eliminate each other inside the diode.
  • Another participant clarifies that current outside the diode is due to the flow of electrons, while inside the diode, it is the movement of electrons that creates the appearance of holes moving in the opposite direction.
  • A further contribution emphasizes that holes do not actually move; rather, electrons move and leave behind vacancies (holes) for subsequent electrons to fill.
  • A participant acknowledges understanding that a hole represents a vacancy for an electron and cannot move.
Participants generally agree on the role of electrons in current flow and the concept of holes as vacancies, but initial confusion about the elimination of electrons and holes indicates some unresolved aspects of the explanation.
The discussion does not fully address the implications of recombination and the steady-state process in forward-biased diodes, leaving some assumptions and definitions potentially unclear.
munna007
doubt in semiconductor diode theory ?
hello friends :smile:...
in this picture diode is forward biased. positive terminal of battery repel holes n negative repel electrons , finaly electrons n holes recombine n eliminate each other.
but its said that current flow is due to electrons . but electrons -holes both are eliminated. then how can we say that current flow is due to electrons.
how can they come out of both terminals of battery as they are eliminated inside ...?
please clarify my confusion...
It is not like that. The current outside the diode terminals (i.e., in the wire) is due to flow of electrons only. But inside the diode, the holes actually did not move. It is the electron which move forward and leaves a hole in backward direction, so as the electron progresses, it appears that hole moves in opposite direction to that of electron. It is a steady state process in forward biased diode, since new electrons come in through N side and after passing through P it reaches the battery and completes its path.
The "holes" (positive) don't move. Only the electrons move. Then the electrons jump to the battery leaving the "hole" for the next electron to jump into.
oki understand now...i think hole is actually a vacancy for electron. it can not move...
thanks friends.
  • · Replies 23 ·
  • · Replies 42 ·
10K
