Draw the graph of arctan((x-1)/(x+1))
The discussion revolves around the graph of the function arctan((x-1)/(x+1), focusing on identifying asymptotes, including vertical and horizontal asymptotes, as well as analyzing the behavior of the function near critical points such as x = -1.
  • Some participants suggest there is no vertical asymptote, while others argue that x = -1 is a vertical asymptote due to the behavior of the function as it approaches this point.
  • Several participants discuss the horizontal asymptote, proposing that as x approaches infinity, the function approaches y = π/4.
  • There is a mention of a jump discontinuity at x = -1, with some participants asserting that the function approaches negative and positive infinity from the left and right, respectively.
  • One participant questions the definition of asymptotes, suggesting that the function getting infinitely close to π/4 might qualify as an asymptote.
  • Another participant emphasizes the importance of understanding the limits as x approaches -1 from both sides and the implications for vertical asymptotes.
Participants express conflicting views regarding the presence of vertical asymptotes at x = -1, with some asserting it is a vertical asymptote while others disagree. There is general agreement on the horizontal asymptote at y = π/4, but the discussion remains unresolved regarding the vertical asymptote.
Participants highlight the need to consider the limits of the function as x approaches -1 from both sides, indicating that the behavior of the function near this point is complex and may involve a jump discontinuity rather than a traditional vertical asymptote.
kolua
I am so far able to find the domain, intercepts, concavity and increase/decrease. But I am stuck at finding the asymptotes for the graph.
I think there is no vertical asymptote or is there one at x=-1?
I think the horizontal asymptote is y=pi/4
##\frac{x - 1}{x + 1} = 1 - \frac{2}{x + 1}##
What happens to ##arctan(1 - \frac{2}{x + 1})## as x gets very large or very negative?
For the vertical asymptote, ask yourself this: can you take the arctan of an undefined value? When will ##\frac{x-1}{x+1}## be undefined?
I think the limit of arctan((x-1)/(x+1)) as x approaches -1 from the right is pi/2 and as x approaches -1 from the left is -pi/2, which means there is no vertical asymptote here but a jump discontinuity here right?
when x=-1 arctan is undefined but as x approaches x=-1 (x-1)/(x+1) approaches negative infinity and positive infinity from left and right. Let (x-1)/(x+1) = t, then arctan(t) approaches pi/2 and -pi/2 as t approaches the two infinity is this correct? then there is no vertical asymptote?
is the horizontal asymptote correct? is there any other horizontal asymptote that I am missing? I got a graph like this, but I'm not sure if it is correct
I don't believe that is so. It is undefined at x=-1, but I don't believe that as x approaches -1 that the function approaches infinity with either sign.
No, x=-1 is the vertical asymptote.
The graph is good.
That's not correct.
Samy_A said:
That's not correct.
Ok, I am probably thinking of an incorrect definition of asymptote. The function does get infinitely close to but never reaches π/4 as x approaches -1. Does this not make it an asymptote?
x approaches infinity and function goes to pi/4 that's the definition of a horizontal asymptote, correct?
Yes that it definitely an asymptote. I'm just not sure about x=-1.
No. A function f has a vertical asymptote at x=a if ##\displaystyle\lim_{x\rightarrow a^+}f(x)=\pm \infty## or ##\displaystyle\lim_{x\rightarrow a^-}f(x)=\pm \infty##.
That's definitely not the case with an arctan.
Ok, my bad.
I'm not sure if the graph looks like that. Because the calculator gives a different image.
That's the graph my calculator gives.
You misunderstood me. I was answering @Isaac0427 's post concerning vertical asymptotes. The definition of a vertical asymptote makes it evident that your function doesn't have vertical asymptotes. At x=-1 it has a jump discontinuity, exactly as you wrote.
I used Atan2, which takes the x and y values separately.
The trickiest part is figuring out what happens as x → -1 from above and from below. It appears from your graph that you've already done that.
But " The function does get infinitely close to but never reaches π/4 as x approaches -1." is not true, because of a mistake in this statement. It's also important to consider the cases x < -1 and x > -1 separately when x → -1.
  • · Replies 19 ·
