MHB Draw Trajectories for Autonomous DE: Where to Begin?
  • Thread starter Thread starter onie mti
    Trajectories
onie mti
when you are asked to draw a trajectory for a an autonomous DE, where does one begin
eg
given the matrix A=
1 0
0 -1
they say find e^tA then draw the trajectories. I know how to find e^tA but i cannot draw
Well, go ahead and compute $e^{t \mathbf{A}}$. You'll have some initial condition $\mathbf{x}_{0}$. Your solution to the DE $ \dot{ \mathbf{x}}=A \mathbf{x}$ is then $e^{t \mathbf{A}} \mathbf{x}_{0}$. Go ahead and perform the matrix multiplication $e^{t \mathbf{A}} \mathbf{x}_{0}$ and see what you get.
My eigenvalues were 2 and 1
Eigenvector associated with λ_1=2 is ■(0@1) and
λ_1= Is ■(1@0)
Where x(t) = c(1)e^(2t) ■(0@1) + c(2)e^t ■(1@0)
Now solving for e^tA
x_1(0)= ■(1@0) = c(1)e^2t ■(0@1) + c(2) e^t ■(1@0)
Where c(1)= 0 and c(2)= 1
Then for x_2(0), c(1)= 1 and c(2) = 0
Such that, x_1(t)= c(2) ■(1@0)
x_2(t) = e^2t ■(0@1)
Therefore e^tA is: ■(c(2) ■(1@0) @e^2t ■(0@1))
I still do not understand how to do the trajectories
Hmm. You might want to check your calculations. With a diagonal matrix, the eigenvalues are simply the values on the diagonal. In this case, you get $\lambda= \pm 1$; the eigenvector for $\lambda=1$ is $\begin{bmatrix}1 \\ 0 \end{bmatrix}$, and the eigenvector corresponding to $\lambda=-1$ is $\begin{bmatrix}0 \\ 1 \end{bmatrix}$. As the matrix is already diagonal, you can exponentiate it fairly easily:
$$e^{t \mathbf{A}}= \begin{bmatrix} e^{t} &0 \\ 0 &e^{-t} \end{bmatrix}.$$
What is your initial condition?
I was not given any initial condition
Ok, that's fine. Let's call the initial condition something arbitrary, then: $\begin{bmatrix}x_0 \\ y_0 \end{bmatrix}$. What is the full solution to the DE?
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
