Which choice should be used for a hollow rectangular bar in MIL-HDBK-5J?
The discussion centers on selecting the appropriate category for a hollow 2024-T3 rectangular bar as per MIL-HDBK-5J. The three options available are: Sheet, Drawn Tubing, and Extruded Bar, Rod, and Shapes. For a hollow rectangular bar, the correct choice is Drawn Tubing, while a solid rectangular bar should be classified under Extruded Bar, Rod, and Shapes. The terms 'drawing' and 'extruding' refer to the manufacturing processes involved in creating these products.
  • Understanding of MIL-HDBK-5J specifications
  • Knowledge of material types: 2024-T3 alloy
  • Familiarity with manufacturing processes: drawing and extruding
  • Basic concepts of mechanical and physical properties of materials
  • Research the mechanical properties of 2024-T3 aluminum alloy
  • Study the differences between drawn tubing and extruded shapes
  • Explore the design properties tables in MIL-HDBK-5J
  • Learn about the applications of hollow versus solid bars in engineering
Engineers, material scientists, and professionals involved in selecting materials for structural applications will benefit from this discussion.
enotyphoon
I have a hollow 2024-T3 rectangular bar and need to check its mechanical and physical properties. So i went through the MIL-HDBK-5J, and it have 3 choice for this material;
1. Sheet
2.Drawn tubing
3.Extruded Bar,rod,and shapes.
so for hollow rectangular bar, which one should i choose. 2 or 3?
and if I have solid rectangular bar, it will be the no 3 right?
1. Sheet
2.Drawn tubing
'Sheet' is just what it sounds like. A strip of metal of constant thickness and constant width which is usually rolled and cut into various lengths, or coiled around a mandrel.
A solid cross section is usually referred to as 'bar' or 'bar stock'. A hollow rectangular section is often referred to as 'tubing'. 'Drawing' and 'extruding' are terms which describe how the finished product is made, usually starting with an ingot.
'Shapes' usually refers to metal in the form of angles, tees, I-beams, etc.
Most tables of design properties often include a picture of the section so that various dimensions can be shown for reference.
Thank you for the explanation. Now I'm understand better.
  • · Replies 19 ·
