DREAD weapon system, power requirements
104 replies · 37K views · last reply
epepep said:
On the weight bit, this guy is obviously a salesman. I think a soldier would be limited to BB's. But a tank-mounted monster disk, weighing 200 kilograms, spinning up over the course of an hour or two, that MIGHT be able to generate some firepower.
Yes, but there´s stiff competition. Modern 120mm tank guns deliver >10 MJ KE per shot at an instant, repeatedly, without the operator having to wait 2 hours.
For less than lethal applications (flinging lots of rubber balls around at ~100 m/s or so) I give the DREAD the benefit of doubt, for everything else it´s just too cumbersome and impractical.
pervect said:
Actually, it isn't at all reasonable. I'm surprised that someone who is a retired physicist could make this mistake. I was actually surprised that there is so much confusion about this very simple issue even by non-physicisits. Especially after the correct answer was pointed out a number of times.
If you shoot bullets out of a gun, they carry momentum. This causes recoil, because momentum is conserved. That's really all there is too it![/COLOR]**************************************
Hey, let's not get wrapped around the axle on this one. I just thought it was a good brain teaser. I'll give you the last comment and promise not to respond -- we'll agree to disagree. The rifle you talk about is very, very different in two important ways, from the spinning disk:
(1) The rifle is rapidly accelerating the bullet, F = ma. So say the bullet weighs 5 grams and the gun weighs 5000 grams; further the bullet is accelerated to 1000 meter/sec, and the rifle barrel is 1 meter long. By using v = at and s = ½at², by algebra, a = v²/(2S), where a = acceleration, t = time, v = velocity, s = distance.
Anyway a = (1000*1000)/(2*1) = 500,000 m/sec²
F = ma = .005 kg * 500,000 m/sec² = 2500 Newtons which is the recoil.
so the acceleration of the rifle
a = f/m = 2500/5 = 500 m/sec²
However, for the disk, the bullet is sitting on the edge of the disk, spinning. The acceleration occurred earlier, perhaps several minutes earlier, when it was accelerated from the center to the outside of the disk. Now it is just spinning at max velocity -- no linear acceleration (ignoring centripetal force). Then it is released.
(2) For the disk, the force does NOT act through the center of mass, as it does for the rifle. It has a lever arm, equal to the radius of the disk. To maintain equilibrium, the forces and moments must equal zero. With the rifle, the moment is zero, so there is a simple backward recoil. For the disk, there must be an opposite moment -- this occurs by a change in the angular momentum of the disk, i.e. the angular velocity. And this occurs when the torque was initially applied -- as the ball was accelerated from the center of the disk to the outside perimeter.
OK, I'll say no more -- you are probably right. That is just the way I, and some other dudes, see it.
[the materials to be used are either so expensive or short supply so u would probably not get many of these weapons made and also the production costs are going to be huge and probably come out of tax payers pockets so i conclude that the money that will be spent on producing this is not worth the benefits (if any) that this weapon will provide.[/QUOTE]
Such utterly huge amounts are spent on other weapons (B2 Bomber = $2Billion apiece, modern fighter $50Million apiece, etc), that I think this technology deserves a shot -- perhaps $50 Million or so. If it doesn't work out -- it was worth the chance. Like everyone here has mentioned, it has some technical challenges -- but I think it shows enough promise to at least investigate it.
True, but the 120 mm gun was developed over several centuries. Perhaps it is worth it to pursue development of this spinning disk thingy for five years or so using modern technology to see what it can do?
That is the stupidest logic I've ever heard.
Why not spend that 50 million solving something more important? We've already shown why the weapon won't work well.
I tend to take the opposite point of view as well - if the inventor/manufacturer think it has potential, let them front some money to deveop it into a real weapon.
I agree that it has some intriguing possibilities, but also agree that there are significant technical challenges (weight, power, and spin-up time) to overcome to make it viable.
My $.02
The idea does not look particularly promising for tanks - you want not only armor penetrating capacity, but accuracy at long range for an anti-tank gun. Accuracy is not going to be a feature of this weapon, with its vibration, gryoscopic effects, and spherical projectiles rotating at 90 degrees to the axis of flight.
It does not look particularly promising for a standard vehcile mount anti-infantry weapon either (IMO). The fact that you can carry a lot of ammo is nice, but the aaccuracy and gyroscopic issues aren't particularly nice.
Where it may have some promise would be where sheer volume of fire power at a relatively short range is important, for instance as a point-defense short-range anti-cruse missile weapon of last result. (The navy has some such system based on conventional high-speed cannon, its name escapes me at the moment). Spin-up time may be a big problem in this application, though.
Possibly it might work as a cannon replacement for aircraft or hellicopters, but I'm not sure about that.
One of the biggest problems is the inventor who is overselling the idea and making elemetary mistakes about physics in the process (elementary to the point where it is apparent he doesn't understand the conservation of momentum!) What the weapon needs is first a better definition of its role, and then a good mechanical engineer type to take a close look at the system (mainly the rotor, though the pointing and aiming systems would also be an issue) to do a preliminary design and stress analysis - or perhaps to seek a very small grant for a person-year's worth of time to do such a preliminary analysis.
At a guess, this will never happen given the current personality of the inventor, who seems to be wrapped up in his own ideas (to say it politely) or a crank ( to say it not so politely).
The name of the system you are thinking of is the Close in Weapons System (CIWS).
Contrary to what the inventor of the DREAD says about his weapon, everything a 120mm gun does is compliant with the laws of physics. You don´t have to ignore conservation of momentum and energy requirements to make it work in your head, like it´s the case with the overhyped DefRev version of the DREAD.
While we´re at it: During the development of guns ball shaped ammunition was abandoned more then a hundred years ago. With advertising it as accurate ammo Mr. St George is a bit late.
The problem here is that you need some range and high muzzle velocity, two things the DREAD will have big problems with due to energy requirements and ball shaped ammo. The Vulcan Phalanx CIWS is often considered too short ranged, against supersonic missiles reaction time is very low and there´s a chance that a missile, while hit by the system, will still impact the ship due to inertia or damage it in a close-by explosion.
In the "New Scientist" article ( http://www.defensereview.com/modules.php?name=News&file=article&sid=727&mode=&order=0&thold=0 ) the following is said: "St George says the projectiles travel at around 300 metres per second upon release from the weapon, about the same speed as a handgun round.". This sounds at least more realistic than the hype in the DefRev articles and is in line with what others and me have suggested:
If it´s going to be real, it will be short ranged and very limited in it´s applications (no tank or ICBM killing, yadda yadda).
Does anyone have the formula for velocity drop of subsonic spherical projectiles in air?
Not at all, but check the ballistics figures for a .38 plus P handgun round (ME, MV, mid-range trajectory, etc.) and cut the numbers by at least 20%.
HOW 'S THIS DREAD SYSTEM DIFFERERNT FROM A BASEBALL OR TENNIS BALL MACHINE[THE ONE THAT THROWS BALLS AT YOU] ,i bet the inventor got the idea from these ,just changed the balls to golf balls ,hehehehehehehehehehehe
STUPID GIT probably could'nt work out the momentum details .
As far as I know, all pitching machines use the same system as the Hot Wheels 'supercharger' I had 40 years ago. ie: the ball (or car) is introduced to the rim of a rapidly spinning wheel(s), and almost instantly accelerated to it's launch velocity. This Dread fiasco seems to maintain them in a constant state of acceleration which is confined by the housing until the release mechanism (and how the hell does that work?) unlocks and let's them out.
i think even in a pitching machine the ball is introduced at the centre of the spinning wheel fitted with throwing arms which is then acclerated[rotated] ,the ball then slides up the throwing arms and flies off tangentially at the realease point which is same as the dread sys ,a slight diff is that it just doesn't hold the balls long enough for the machine to accelerate it to a high speed .
yup ,to me they're both same .
That might be right. I've only seen them from a distance or on TV. Regardless, no one ever claimed that they have no recoil. They also have a barrel of sorts for accuracy.
My approach would be to try to 1. not put the cart in front of the horse, and 2. not to reinvent the wheel.
There were some claims by the inventor and the supporters of the inventor that the weapon has "no recoil", emphasis on quotes. I will quote more loosely the other claims because I can't be bothered to look them up and that would be the 8,000 fps projectile velocity, with 120,000 rounds per minute, and a 150 W power supply.
All you need to do is to take the weight of the projectiles, the velocity, the firing rate, and to calculate the power requirement. Use physical constants like conservation of energy and momentum. Take the energy of each projectile divided by the rate of fire and come up with power. It's easy. You can also calculate the force on the weapon which will create recoil. And of course you, as physics students, know that this weapon cannot fire projectiles of ANY mass without recoil. That alone is enought to debunk the whole thing.
This thing is a hoax. Use your basic skills in physics.
I woudnt be so quick to dismiss this, especially since they are claiming a working prototype. I can think of several things rite off the top of my head to counter some of the major problems you are citing. Going by the patent info is useless, since it could be purposely misleading to keep the device from being copied. Same thing could apply to some of the obviously wild claims.
Not if it's obtained from the Patent Office.
I guess there's one born every minute, as PT Barnum said.
Maybe you have yet to discover the value of patent 'protection', Danger. The only real way to protect an idea is to keep it out of the heads of anybody who may want to steal it.
I have a pretty fair exposure to patents, actually. Information obtained from a Patent Office is a copy of the original filing. No one knowingly files false information in a patent application for a practical product, because it doesn't protect the real design. The patent is for legal purposes only, giving you the right to seek compensation through the courts if someone kifes your idea. A false filing would do nothing in that regard, and anyone can still 'reverse engineer' the thing once they see it.
1. Velocity 800 ms ~ approximation from literature
2. Diameter 762 mm – assumed from “32 inches wide” in literature
2. Rotational Speed ~ 20051 RPM (335 Hertz) - derived from diameter assumption.
3. Feeder Trays - 20 (from literature).
4. Mass of projectile: 4.633 g - Huh? I would use 3.7 grams. You don't know the exact alloy so the density is +/- 1 percent. A stainless steel dimpled ball of 7.62mm (.308) diameter is 1.7 grams, 12.7 mm (50 caliber) is 8.3 grams (1-2% loss due to dimpling) . Density is 18.8 for tungsten, 15.7 g/cm3 for tungsten carbide, and 8.0 for stainless steel. The steel ball weights are for actual steel balls (commercially available) derated 1% for dimpling.
5. Shot burst: 10. This causes some conflict with the 120000 rounds per minute number since it implies a rotation speed of 12000 rpm (200 hertz). Which implies the production device will be 1.3 meters wide (allowing for outer casing width).
From the above:
1. The device fires 10 rounds per spin (1/2 of trays). As long as the device is programmed to fire in units of 10 it will only experience rotational torques for a fraction (9/10th) of a rotation and will be balanced when not firing.
2. The device fires in a 2 cycle round robin. This gives the 3 ball shot advance mechanism 2 cycles to move the next ball in a set of trays into position.
3. The device operates at the speed of a high performance hard drive (which takes 7 watts and can spin up in several seconds).
4. There is talk of "reloading/rearming" in the patent. Although a gatling gun loading mechanism is possible (dump shot into the center of the disk and let rotational inertia fill the slots) reloading and firing are apparently separate steps.
5. I am familiar with mechanical harvesters (for tree crops) which use 30 hertz rotations, and 100 lb edge weights on 2 ft reaction wheels. The rotational speed of the harvester is 1/10 that of the Dread device resulting in accelerations 1/100 as great on an weight imbalance 10000 times greater. The havester is not destroyed by use. Pneumatic isolation of the disc (perhaps with fluid dampening) will be sufficient to deal with the momentary imbalances. The motor should be connected to the wheel with a flexible coupling.
6. If the weight imbalance acts through the center of mass on the axis the net effect of the forces won't cause precession, i.e. the forces won't have a component perpendicular to the plane of rotation.
7. Start up torque requirement. For the sake of argument we will assume that the weight of the ammunition (308 caliber) is 3700 grams. The weight of the “disk” is assumed to be the same as that of the ammunition. Total weight 7.4 Kg. Radius = .76 m. Moment of inertia ~ 2.14 kg/m2 (solid cylinder approximation). 5 second start up is assumed (same as a computer hard drive).
a = Δv/Δt
acceleration = 2* Π * 335 hertz/5 = 210 rad/s2
t = Ia = 2.14 kg*m2 * 210 /s2 = 449 kg * m2 /s2 = 449 Nm
449 NM is a fairly large electric motor (on par with an engine dynamo). So the system is practical but has a fairly long “arming” period (longer than the 5 seconds used for illustration) for the disk to spin up prior to firing. There will be a loss of rotational speed during continuous fire. Making the inertia of the disk greater will mitigate this.
While you're at it:
centripetal acceleration of disk:
(800 m/s)^2 / .4 m = 1,600,000 m/s^2
(I used 400 mm for the radius, that's rounded up, and closer to 16" than your figure).
For comparison, a typical high speed centrifuge generates "up to 30,000 gravities" (from the www - that's only 300,000 m/s^2), and it has only a static load, not the dynamic load generated by feeding it bullets.
I think if you look back in the thread you'll see calculations that the 800 m/s version will fragment a steel rotor even without any other loads.
These are values I approximated by looking at the patent paper, the DefRev article and by using common values in current weapon tech (bullet speed and diameter) for comparison. I set density of Tungsten to 20 g/ccm, that´s not too far from 19.3g/ccm you commonly find.
Well a hard drive doesn´t spin that fast (yet), and it´s a closed, light system, so the comparison doesn´t tell much.
Do you got a picture of these? Isn´t there a counterweight so net centrifugal forces amount to zero?
Well, the thing will still react wildy to changes in direction due to gyroscopic effect. I think that was the main issue presented here.
449NM might doesn´t seem much, but 449NM at 20000 RPM isn´t quite as easy to achieve, IMHO something like this will badly get into the way:
Graph titled D.C. Motor Torque/Speed Curve: a straight line falling from stall torque (τs) on the torque axis to no-load speed (ωn) on the rotational speed axis.
No matter what the torque requirements are, the power requirements I calculated are valid and in the Megawatt range. It might be possible to make the problem sound small by presenting a value like 449NM, but that doesn´t mean you don´t have to put an average of 0.98 MW into the system in my intial example.
Making the inertia of the disk greater might help mitigating the velocity loss of the ammo, but it also means you have to put much more energy into accelerating the whole thing, see my 20kg and 200kg disk examples above.
As Pervect said, just playing around with disk mass isn´t that trivial either, as strain on material is very high, making it a whole topic for itself.
Almost no recoil
Hey guys,
here comes the next foreigner with bad english.
I'm from Germany
I read your whole discussion, and if you consider the projectile which is shot, is not replaced by another one, there will definitely be a recoil.
But, just imagine two rails spinning round the center of a closed circled box. (check attachments)
If you then put a ball in the middle, it will be draged out as far as possible.
If you now put in 20 on each rail and one ball is released from one of the two rails another ball wil replace it at once.
The difference of weight on the one rail will be almost in the center of mass, and if balls a continously supplied eliminated at once.
  • Diagram of a circular housing with a horizontal row of dark red balls on a track, with black arrows showing the balls moving left and right, and a vertical arrow at the right where a ball exits upward.
It claims to be virtually silent haha, when was the last time you heard (sorry didnt hear) an electrically powered centrifuge that runs at 120,000rpm... This review SoldierTech reads like some trekky has had too much coffee when writing the review...
It may be virtually silent when running in your head.
To the original poster, yes you are absolutely correct. This is the true content of the equivalence principle, that a freefalling observer is in a locally flat spacetime, just like an observer moving at constant velocity. In freefall we do not feel our own weight, this is what is meant by weightlessness i.e. the lack if a force.
Recoil? Nonsense! Precession? Nonsense!
A counter-rotating disk of equivalent mass will eliminate precessional effects. Not an issue.
Once the gizmo is up to speed, with fully loaded ammo channels, you've essentially got a flywheel... which wants to stay in motion (according to Newton). The only subsequent energy requirements will be what is required to restore angular momentum lost to frictional forces, and the minimal inertial forces involved in accelerating individual pellets in 1/50th-D. step increments.
Re recoil: When a pellet is released, there will be no recoil. Think about it... a bit of the mass of the flywheel will be lost. Under constant power input, the darn thing would be trying to speed up... not slow down. Of course, a velocity servo control system would tightly control that.
Unbalancing: Not an issue. Remember, the thing has a magazine capacity of 10,000 (.50 cal) or 50,000 (.308 cal) rounds. Suppose that there are around 1,000 pellets (.308) in the flywheel channels (20 x 50). That tells us that there is a central hopper full of pellets, supplying a chamber where there are a whole bunch of pellets, whirling around, desperately trying to get into the feed channels... but being prevented from doing so by virtue of the fact that the feed channels are already full. When a pellet is released, the pellet column instantly advances .308 inches, and the expended pellet is instantly replaced... the channels essentially remain solid. Any purturbance in the system created by the 'release' (NOT 'discharge') of a pellet... a very tiny fraction of the mass of the flywheel system... will be very minute, and very short-lived. So, there might be a tiny bit of vibration, which can be dampened by a sufficiently robust support/drive system. (This is probably the reason that there are 20 channels, rather than 6 or 10 or 12... or 24 or 36. Too few channels... to much vibration. Too many channels, too much additional flywheel bulk required to maintain integrity.)
Re recoil (again)... and conservation of energy: The 'recoil' is pre-loaded into the system, and is felt long BEFORE a pellet is expelled. The energy expended in bringing the flywheel (including its full load of pellets) up to its designated rotational speed is the equivalent of the 'recoil' experienced by conventional munitions.
Re Spinning projectiles: Get a golf ball, and drill a hole through it. Attach about 3-feet of kite string. Twirl it around your head, as fast as you can, then let go of the string. Does it spin? (Hint: No.)
It seems to me that such a system will operate pretty much as claimed by the inventor, and the only real impediments would be materials-related... i.e., building it from something that won't come totally unglued at the desired angular velocities. Also, diven the spherical projectiles, it probably only sufficiently accurate over relatively short ranges, compared to conventional munitions. Of course, the sheer volume of fire might mitigate that deficiency, to an extent.
Your examples are ill-conceived at best, and misinformation at worst. Several people have gone through intensive calculations analyzing the power requirements and physics involved. Unless you have some ACTUAL MATH to prove you point, your claims are no better than the mud-slinging inventor's.
Easy Peasy mate
Took me maybe 10 minutes figure this one in the rough.
counter-rotating room-temp superconductor electromagnetic centrifuges with center feeds.
https://www.physicsforums.com/images/smilies/cool.gif
:cool:
This balances effects of lost angular momentum by paired synchronized fire from centrifuges with opposite spin. No mechanical rotor.
https://www.physicsforums.com/images/smilies/love.gif
Bullets are magnetically levitated so as not to touch the interior once feed in - so frictionless. Magnetic gating of projectiles. Gee doesn't this sound like a pair of Cyclotrons scaled up to macroscopic particles via the miracle of superconductors?
No moving parts past the feed mechanism...and probably not there if you are clever (magnetically siphon out ammo from ammo tank).
Power arguments? Really moot. It is common for weapons to quote fire rates that cannot be sustained. So yes you are limited to the energy available during a given firing period. https://www.physicsforums.com/images/smilies/rolleyes.gif
:rolleyes:
But then again lasers commonly store up energy in capacitor banks for discharge over a short period of time. So DREAD can meet its specifications for short burst fire. Very short bursts with long recharge times for man portable. Several or longer bursts with HUMVEEs helicopters etc with short recharge periods.
https://www.physicsforums.com/images/smilies/blushing.gif
:blushing:
Of course several other weapon systems have started needing higher energy power plants with HUMVEEs. Not that I am endorsing them as practical or wise for the battlefield -- but reports exist of multi-megawatt power sources to accompany HUMVEE and small truck lasers coupled with large quick discharge power banks. Hmmm I wonder what a stray penetrating round would do there? Similarly what happens if those superconductors in the weapon breakdown? I am betting you don't want to be the gunner in a HUMVEE or man portable -- crispy critter time.
https://www.physicsforums.com/images/smilies/surprised.gif
Accuracy...hmmm. Well further electro mechanical gyroscopic gun stabilization would likely help (sort of like Abrams) sink minor vibrations. Plus nothing says you can't add a follow on magnetic Gauss gun barrel to correct aim point velocity after the ammo is "charged" with KE directed in approximately the right direction.
https://www.physicsforums.com/images/smilies/angel.gif
o:)
Plus the anti-tank guys are missing the fact that the decreased spacing of arriving ammo is even like hydraulic drilling to armor. This gun can just afford to paint more square inches of armor with effect. Effectively the same weight of ammo is delivered per square inch even spread out a bit. That is IF there is increased drift over more stable guns, it is countered more total arriving ammo. And I am not really sure we have reason to believe there there will be more drift over something like the A10 30mm gun - after all that vibrates the whole plane in space. You need a real weapons tests or full engineering data and simulation to even speculate on this.
https://www.physicsforums.com/images/smilies/redface.gif
:redface:
But what if the bullets are spun by a pair of counter-rotating superconductor electromagnets? https://www.physicsforums.com/images/smilies/love.gif
Then the only moving part is the bullets. And I suspect the chamber quickly becomes a vacuum during fire. Basically this is a Gauss gun circularized to solve the recoil and barrel length problems.
https://www.physicsforums.com/images/smilies/biggrin.gif
:biggrin:
However, the gun could still be located by stereoscopic acoustic analysis of the sonic cracks. Easily performed by a PDA and a couple of sound guns at known baseline locations a few hundred meters apart -- or militarily a radio linked system of two or more GPS locatable mobile parabolic dishes.
The real point being that an unaided human spotter couldn't locate such a superconductor gun. I forget the precise length of the base line for triangulation required. Something like it has to be longer than a halfwave length of the shockwave at the speed of sound at the observation points.
