Windows on Mac: Dual Boot or Virtual Desktop?
The discussion centers on the decision between using dual boot or a virtual desktop to run Windows applications on a Mac. Users recommend virtual machines, specifically VirtualBox, for running less resource-intensive programs, while noting that dual booting may complicate file sharing and require additional installations. The conversation highlights the feasibility of using USB memory sticks for data transfer and suggests that some Windows programs, particularly those written in C++, may be recompiled for Mac. Ultimately, the consensus leans towards using a virtual machine for convenience and efficiency.
  • Understanding of VirtualBox for creating virtual machines
  • Familiarity with C++ programming and compiling
  • Knowledge of file sharing methods between different operating systems
  • Basic understanding of Mac OS and Windows environments
  • Research how to set up VirtualBox on macOS
  • Learn about configuring shared folders in VirtualBox
  • Explore methods for recompiling C++ programs for macOS
  • Investigate the requirements for running Windows applications on macOS using Darwine
Mac users needing to run Windows applications, software developers working with C++, and anyone looking to optimize their workflow between macOS and Windows environments.
dRic2
I need windows on my mac to run some modeling programs, but I'm not sure whether go for dual boot or virtual desktop. I have all my programs already installed and I fear that dual boot + installing all the programs again will suck too much memory space... on the other hand I have never enjoyed the idea of virtual machines.
Any suggestion?
Thanks
RIc
Computer science news on Phys.org
Ram space would be unaffected by dual boot. Can you buy and install a second hard drive into the Mac and install windows on the second drive?
Thanks, but I've never done that, I'm going to look it up on google.
Otherwise I could sell my mac and buy a new pc... :olduhh:
You’re better off having separate machines running in parallel instead of dual booting especially between Mac and windows. Filesharing becomes an issue with respect to text files the lf vs crlf line termination as well as other things.
Likes scottdave
Well I'd like not to buy an other computer. If that is the case, then I'll probably have to sell my mac
Windows machines are pretty cheap relative to what you paid for the Mac. Also the Mac has a unix-based OS and in the ling run for software development, its a better platform especially if you also need to develop for Linux too.
That's way I saved up money and I bought one... and it took me quite a long time too. Plus I had like 200 Euros of discount. If I buy a windows pc only to run this program it will be, to me, just a waste of money, and I can't afford to spend 700/800E for a windows pc with very high specs.
I'll see what I can do
What modeling program are you using? Blender and Maya both run on Mac, I do plenty of 3D modeling and it's all done on my Mac. Even if it's Windows-only, it's entirely possible you could simply run it as-is through Darwine. I have many Windows-only programs running on my Mac through Darwine wrappers.
I have used Parallels on my Mac with good results (but only with Windows XP inside).
Likes scottdave
I use Virtualbox on my Mac with a Windows 10 VM. It works very well but needs quite a lot of RAM for the VM not to impact on Mac OS X too much. I wouldn't use the Windows VM for doing much modelling work though. If I need to do that I use a Windows box and use remote desktop to it.
Cheers
Hi, I think modeling is the wrong word (I apologize). Basically I have to run this program, written in c++, to simulate the behavior of a flame. It's just lots of calculations, nothing special. I'd like to use MATLAB and excel too (that I've installed on my mac). It's written by my professor and I think it is windows only since it runs a .bat file and use the command prompt as main window.
I've a macbook air
I've a macbook air
Is it all DOS? you can look at the .bat file with a text editor, to see what it does.
The program is actually very easy. I've to write some text files with all the properties I want and the right algorithms and then give them to it. It's like a compiler
Running the program under a virtual Windows is probably the best approach, unless the program is very resource intensive.
If it is very resource intensive, it could be still better to increase memory on your one machine.
A second PC to run one program is a technically more efficient solution, but could be unnecessarily more expensive .
Dual boot is a possibility, but freqently rebooting could get painful.
If it’s written in c/c++ then you might be able to recompile and run it on your Mac. The gotcha would be if your prof used windows specific apis or windows GUI.
However, if it simply computes and writes to the screen or a file then there’s a good chance it can easily be rebuilt on Mac.
Likes NTL2009
it depends on what I have to do. For now it seems a light program, but maybe next year things will get harder. I think I'm going to go for virtual windows and see how it handles it. By the way I have one more question about virtual machines. I really need to copy the output files of this program in MATLAB and excel so I was wondering: is file sharing easy on virtual machines?
Unfortunately I think so, because when I tried it on a friend pc I had to change some Windows Environment Variables
You can make a partition on your hard disk which is there for shared data.
Not what I would call easy, but doable.
You mean a real partition? Or a virtual one? This is not a good news... :(
An actual disk partition on your hard drive which physically exists and is accessible from whatever OS is looking.
Likes dRic2
Why life has to be so complicated?:frown:
Or a separate disk drive just for the shared data. most PCs (not laptops} will accept two physical drives.
Not as expensive a whole new PC, but going that way
It seems my post didn't go through earlier. Have you inspected the BAT file with a text editor to see what it does?
Oh I'm very sorry. The .bat file just calls an .exe file.
Ha. Ok. So I guess the exe is the compiled C program
Yep, sorry. I know I wasn't very clear
Ive done a dual boot Ubuntu on a Windows PC before. I've heard of Virtual box but never set one up. Is there a lot to it?
The main problem of virtual machines is that I will have to install Matlab and Excel again on virtual Windows (I will lose memory for nothing) or I need some way to share the output file from virtual Windows to Matlab and Excel on my mac. I don't know if there is an easy way to do that
I was mentioning earlier that you could make a disk partition or even install a second disk drive for shared data.
Now I think I have a better idea.
You could get one of those cheap USB memory sticks. use that for shared data.
If both OS's can see the memory stick it could work (I think).
Likes dRic2 and scottdave
Yes, and find out what exactly the requirements are for this simulation program is. Maybe you do not need all of Windows for it to run
Likes dRic2
I'll give it a try. Thanks for all the good suggestions :)
  • · Replies 18 ·
  • · Replies 104 ·
  • · Replies 21 ·
  • · Replies 16 ·
90K
