Dual particle and dual double slit interference
San K
In short the question I am trying to answer is:
1. do the "waves-functions" from separate particle interfere?
2. do the Schrödinger equations predict the interference pattern caused by the interference of the "wave functions" of two separate particles?
The above question is illustrated/clarified below in the form of an experimental setup:
we have two double slits placed side by side and a particle for each of the double slits traveling at same time.
lets say we have an experimental setup where we have a single particle (photon/electron) headed for double slits (labelled A1 & A2).
Now we create another double slit setup exactly similar as above. The double slits, in this case, are labelled B1 & B2.
We start bringing the double slits close to each other. close enough that the "wave function" emerging from, say, A2 can interfere with the "wave function" emerging from, say, B1.
Case 1: the single particle headed for double slits A1 and A2 is a photon
the single particle headed for double slits B1 and B2 is also a photon
Case 2: Case 1: the single particle headed for double slits A1 and A2 is a photon
the single particle headed for double slits B1 and B2 is an electron
Possible, depends on the situation.
If you use the correct wave functions: Yes.
With two independent photon sources you won't see interference effects. But if you can guarantee that the photons have a fixed phase relation then you get interference.
Then you will detect one photon and one electron, independent of each other.
