Calculating Masses in a Dynamic Pulley System
  • Thread starter Thread starter PhoenixWright
    Dynamic Pulley
The discussion revolves around calculating the mass m1 in a dynamic pulley system involving two masses, m1 on a plane and m2 hanging from a pulley. The user initially derives an incorrect equation for m1 and seeks clarification on how to arrive at the correct formula. Key points include the consideration of forces acting on both masses, with m1 experiencing tension and gravitational force, while m2 is influenced by tension and its weight. The user realizes that the problem was misunderstood, as it involves two pulleys instead of one, leading to the conclusion that their initial equations were based on an incorrect assumption about the system's configuration. Ultimately, the confusion was resolved by recognizing the complexity introduced by the additional pulley.
PhoenixWright
You have a a mass, m1, in a plane. This mass is connected to a pulley by a thread, to a mass m2. Prove that:
\begin{equation}
m_{1} = \dfrac{m_{2}(2g - a)}{4a}
\end{equation}
I don't know why, but I can get this:
\begin{equation}
m_{1} = \dfrac{m_{2}(g - a)}{a}
\end{equation}
It's a similar equation, but it's not the same. How can I get the right solution?
Thank you!
m1=m2(g−a)a​
(2)(2)m1=m2(g−a)a\begin{equation} m_{1} = \dfrac{m_{2}(g - a)}{a} \end{equation}
how you take a start-give free body diagram of the masses?
m1 is in a plane (it's not inclinated) and m2 is is hanging from a pulley. They are connected by a thread.
In m1 we only consider Tension force (because N = mg), and in m2 we consider Tension force and m_{2}g
Thanks
Thanks
so , how you write the equation of motion? the pulley is massless or not? if m1 is sitting on a plane will there be motion?
The pulley is massless. The plane has no motion.
I use this:
\begin{equation}
m_{1}\vec{g} + \vec{N} + \vec{T_{1}} = m_{1}\vec{a_{1}}
m_{2}\vec{g} + \vec{T_{2}} = m_{2}\vec{a_{2}}
\end{equation}
Therefore:
\begin{equation}
T_{1} = m_{1}a_{1} \ \\
T_{2} - m_{2}g = m_{2}a_{2}
T_{1} = T_{2} (massless)
a_{1} = -a_{2}
\end{equation}
Then, I got the equation I put before... But it's not what I must get.
i just feel that how the mass m1 can move sitting tight on the plane- if it is raised from the plane by the string then what happens to gravitational pull-sorry i can not visualize it ,pl make the dynamics more clear
This is a pic of the situation:
in the above case your equations seem to be correct but the accelerations are not related like a(1) = -a(2) as one is horizontal and the other is vertical
Thanks, but, anyway, I can't get the solution if I suppose a1 = a2...
Problem solved. The exercise was wrong, there were 2 pulleys, not only 1.
  • · Replies 17 ·
