Dynamics: half-cylinder rolls without sliding.
  • Thread starter Thread starter etotheix
    Dynamics Sliding
The discussion focuses on the dynamics of a half-cylinder rolling without sliding, specifically addressing the conservation of energy principle and the calculation of forces at the point of contact. The correct approach for part a) involves using the formula T2 = (1/2)m(vG)^2 + (1/2)Iω^2, where T1 = 0 due to the system starting from rest. The confusion arises in part b) regarding the normal force at point C, where the correct radius of gyration (rG) is identified as (4r)/(3π) instead of the initially assumed value. The distinction between inertial and non-inertial reference frames is crucial for accurate calculations.
  • Understanding of the conservation of energy principle in mechanics
  • Familiarity with rotational dynamics, including moment of inertia (I) and angular velocity (ω)
  • Knowledge of kinematic relationships in rolling motion
  • Ability to differentiate between inertial and non-inertial reference frames
  • Study the conservation of energy in rotational systems
  • Learn about the moment of inertia for various shapes, including cylinders
  • Explore the principles of rolling motion and the conditions for rolling without slipping
  • Investigate the effects of different reference frames on dynamics problems
Students and educators in physics, particularly those focusing on mechanics and dynamics, as well as engineers working with rotational systems and motion analysis.
etotheix
[PLAIN]http://img62.imageshack.us/img62/6531/capturefma.jpg
Conservation of energy principle
T1 + \sum U1-2 = T2
I have the correct answer for part a).
T1 = 0 (since the system starts from rest).
T2 = (1/2)m(vG)^2 + (1/2)I\omega^2
I believe that the instantaneous center is located at the point of contact of the half-cylinder and the ground after the 90 degree rotation, let's call this point of contact C. So vG = \omega * GC
GC = r - (4r)/(3\pi)
From here I get the correct \omega, the real problem comes when I try to solve part b), which asks for the normal force at point C.
My strategy is to use the force and acceleration principle in this way:
\sum Fy = m(ay): N - mg = m(rG)\omega^2
But the problem is that I use rG = GC = r-(4r)/(3\pi), but in the solutions they use rG = (4r)/(3\pi), why is that? Is to half-cylinder rotating about O? If so why are we using rG = GC in part a) of the problem?
Thank you in advance for the help.
I think you made a mistake in the solution for a, despite getting the right result. For pure rotation, you can either choose the point of contact or the center of mass as your reference point. If you choose the center of mass, you must use the body's rotational speed with respect to its center of mass, as seen in an inertial reference frame. The contact point is not inertial, so you can't use its reference frame. Rotational kinetic energy would be given be the usual 1/2*I*w^2, and translational kinetic energy would be 1/2*m*(GC*w)^2 because w is how fast GC is rotating with respect to the horizontal.
So in the end, we get the same equation you initially got for part a. Note that w was with respect to an inertial frame, and represents the rate at which GO is rotating.
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 60 ·
