Dynamics - relative motion, planes Q
The discussion revolves around calculating the relative acceleration of two aircraft, A and B, flying in opposite directions along a circular path with a radius of 5 km. Aircraft A travels at 125 km/h in an anti-clockwise direction, while Aircraft B flies at 225 km/h in a clockwise direction. The key equations used include the relative acceleration formula aA/B = aA - aB, and the angles of the velocity vectors are determined to be θA = 315° and θB = 225° when measured counterclockwise from the positive x-axis. The conclusion emphasizes the importance of consistent angle measurement for accurate calculations.
  • Understanding of circular motion and angular velocity
  • Familiarity with vector addition and subtraction
  • Knowledge of trigonometric functions for angle calculations
  • Basic principles of relative motion in physics
  • Study the principles of circular motion and centripetal acceleration
  • Learn about vector decomposition and how to resolve vectors into components
  • Research the concept of relative velocity in different frames of reference
  • Explore the use of Oxy diagrams for visualizing motion in physics
Students studying physics, particularly those focusing on dynamics and motion, as well as educators looking for examples of relative motion and vector analysis in circular paths.
chuffy
Aircraft A is describing a circular flight path in an anti-clockwise direction at 125km/h
Aircraft B is flying the same path but in the opposite direction at 225km/h.
If the radius of the flight path is 5km, calculate the acceleration of A relative to B when Aircraft A is heading South-East, with aircraft B is heading South -West
aA/B = aA - aB
Simple looking question but I'm falling at the 1st hurdle with obtaing the angular orientation of each Velocity vector of each Aircraft
My frame of reference is an Oxy diagram
The worked soultion from my tutor is:
θA = 45° when heading south-east
θB = 135 when heading south - west
I don't get the same angles as the worked example & I've doubled checked the directions of the flight paths (A flying anti-clockwise , B flying clockwise)
The only time my angles match the worked soulution is when I make A fly clockwise & B fly antiCan someone check to worked soultion is correct with the question & explain it to me or am I right?
Cheers
The angle depends upon from which axis it is measured and in which direction.
θA = 45° clockwise from the + x-axis when heading south-east
θB = 135 clockwise from the + x-axis when heading south - west
By convention, angles are usually measured ccw from the + x axis, so θA = 315 degrees counterclockwise from the + x-axis when heading south-east
θB = 225 counterclockwise from the + x-axis when heading south - west
In reality, a pilot measures his or her bearing clockwise from magnetic north, so SE is 135 degrees and SW is 225 degrees.
In the end, the relative accelerations come out the same no matter how you choose your angles, as long as you are consistent..
Thanks for the detailed reply
The 1st part of your answer matches my thinking that θA is° flying clockwise
However, the question states anti-clockwise
However, I tried your method of being consistent with measuring the angles from the x-axis & going counter clockwise to get a positive angle & it worked.
I think the circluar flight paths were throwing me off as on one question it stated:
Aircraft A flys counter clockwise & is heading south. I thought the angle would be 180° but I now understand why it is actually 270°
  • · Replies 60 ·
