Tall building sighting distance
  • Thread starter Thread starter Echoing Stars
The discussion centers on calculating the height required for a building, specifically the Burj Khalifa, to be visible from a distance of 250 kilometers. The consensus is that the building must be approximately 4.9 kilometers tall, derived from the formula h = √(R² + d²) - R, where R is the Earth's radius and d is the distance. A more precise calculation using the Earth's radius at 25°N (6374.344 km) yields a height of 4.90058148 km. Additionally, the equation can be used to determine the distance from which a building of 0.8298 km can be seen, resulting in approximately 102.857 km.
  • Understanding of basic geometry and the Pythagorean theorem
  • Familiarity with Earth's radius measurements
  • Knowledge of line of sight calculations
  • Ability to interpret mathematical equations
  • Research the formula for calculating sight distance based on Earth's curvature
  • Learn about the impact of atmospheric refraction on visibility
  • Explore advanced geometry concepts related to spherical objects
  • Investigate the visibility of other tall structures from varying distances
Mathematicians, architects, engineers, and anyone interested in the visibility of tall structures and the calculations involved in line of sight analysis.
Echoing Stars
From what distance can a person on the ground see the Burj Khalifa?
Or: How tall does the building have to be to be seen from 250 kilometers away?
##4.9 \,\text{km}##
What you said: The building needs to be 4.9 km high to be visible from 250 km away?
I would like an explanation of the equation that produced this result.
See. And I would have liked to have seen some effort from your side to solve the problem.
russ_watters said:
I scribbled it on a tiny kid's toy so I may have made a mistake, but I don't think so.
I used the polar Earth diameter from Wikipedia, ##12713\,\text{km}## and the distance ##250\,\text{km}## as line of sight. I reviewed it, and it is a little more than ##4.9\,\text{km}.##
Solve: ##0=(r+h)^2-r^2-(250)^2##
You are a champion.
This is my equation:
h=63712+2502−6371h = \sqrt{6371^2 + 250^2} - 6371
Echoing Stars said:
You are a champion.
I think you have been a bit sloppy in the first equation. The same formula (Pythagoras) also allows you to solve for the distance ##x## if you use the radius 6374.344 km and height (peak) 0.8298 km of the actual building. Then ##x=102.857\,\text{km}.##
fresh_42 said:
אני חושב שהיית קצת מרושל במשוואה הראשונה. אותה נוסחה (Pythagoras) מאפשרת לך גם לפתור את המרחק ##x## אם אתה משתמש ברדיוס 6374.344 ק"מ ובגובה (שיא) 0.8298 ק"מ של הבניין בפועל. ואז ##x=102.857\,\text{km}.##
And it's just like that..
Look here
Sorry, there were two questions asked: I thought you were answering the first and I skimmed past the second.
  • · Replies 20 ·
  • · Replies 21 ·
