Earth's rotation having effect on sub-orbital trajectory
  • Context: Graduate
  • Thread starter Thread starter ellipsis
    Rotation Trajectory
The discussion revolves around the effects of Earth's rotation on the trajectory of a thrown object and its implications for achieving orbit. Participants explore theoretical scenarios involving sub-orbital trajectories, the influence of rotational velocity, and the necessary conditions for achieving orbit from a single launch.
  • Some participants suggest that a ball thrown high will land in a different spot due to Earth's rotation, raising questions about the nature of its sub-orbital trajectory.
  • There is a discussion about whether attaching thrusters to the ball and firing them at the apex would require less fuel if the Earth is rotating, with some noting that the direction of the thrusters matters.
  • One participant proposes that raising an object high enough could allow it to achieve orbit using only the tangential velocity provided by Earth's rotation.
  • Calculations are presented regarding the radius needed for centripetal acceleration to maintain a circular orbit, with differing results noted by participants.
  • Participants discuss the concept of throwing an object with tangential velocity relative to Earth's rotation and how this affects the trajectory.
  • Clarifications are made about the nature of trajectories, including circular, elliptical, parabolic, and hyperbolic paths, depending on the launch conditions and velocities achieved.
Participants express differing views on the implications of Earth's rotation for achieving orbit, with no consensus reached on the calculations or the nature of trajectories resulting from a single launch.
Discrepancies in calculations and interpretations of trajectories highlight the complexity of the problem, with assumptions about reference frames and launch conditions remaining unresolved.
ellipsis
If you throw a ball obscenely high (ignoring air resistance, etc), and the Earth is rotating, the ball will land in a different spot. Relative to an observer on the Earth, the ball has a sub-orbital trajectory across the surface. If we attach thrusters onto that ball, and have it burn at its top point until it achieves orbit, will its expended fuel be less than if the Earth wasn't rotating?
Taking this to the extreme, if the Earth was rotating very quickly, would shooting something out of the atmosphere be sufficient for it to be in orbit? Or would it follow a spiral-like trajectory across the surface? Is the reference frame of an Earth observer useless because it is non-inertial?
That depends entirely on which direction you're going to make the thrusters fire - against or with the rotation.
There's no need for extreme changes in rotation. Providing you raise the object high enough, it can get in orbit with only the tangential velocity of the rotation.
Try calculating the radius at which centripetal acceleration provided by Earth's gravity is just right to curve the path of an object moving at the speed of Earth's surface at the equator.
As you wish: 1.84 * 108 km, given a resulting circular orbit. I suspect the height for an elliptical-but-stable orbit is less, but the calculation is harder.
I get 1.84 * 106 km ([itex]GM/(R\omega)^2[/itex])... 1.84 * 108 seems like a large number... 25% further than the distance between the Earth and sun.
I had a conversation with my professor, and came to an understanding - within the reference frame of 'space', what's happening is the object being given tangential velocity equal to the Earth's rotation. This means that you're essentially throwing it at a vector relative to the Earth's surface. You can create as big a parabolic trajectory as you want (even reach escape velocity), but you can't get it into orbit from a single throw.
What is "throwing at a vector"? Relative to the Earth's surface it is thrown vertically, with no tangential velocity. Relative to an inertial frame it has a tangential velocity equal to the Earth's rotation.
By 'vector' I mean the combined vector of the vertical and tangential velocity. Throwing something upward on a spinning globe is equivalent to throwing something at an angle on a non-spinning globe.
It will not be a "parabolic" trajectory unless you happen to achieve escape velocity exactly. It could be...
A circular trajectory, if it were not for the fact that the launch angle has a vertical component, so it can't be that.
An elliptical trajectory. Which would intersect with the surface of the earth. So eventually your projectile will crash. That's the key problem with getting to orbit in a single throw.
A parabolic trajectory. If launched exactly at escape velocity.
A hyperbolic trajectory. If launched in excess of escape velocity.
A straight line (degenerate ellipse, parabola or hyperbola) if it were not for the fact that the [inertial-frame-relative] launch angle has a horizontal component, so it can't be that.
  • · Replies 37 ·
  • · Replies 35 ·
17K
  • · Replies 1K ·
36
191K
13K
  • · Replies 44 ·
16K
