Easiest way to calculate the Sum of Harmonic serie?
  • Thread starter Thread starter Horse
    Harmonic Sum
The discussion focuses on calculating the sum of the harmonic series, specifically \(\sum^{30}_{i=1} \frac{1}{i}\). Various methods are explored, including the Euler-Maclaurin summation formula and integration techniques. Users debate the effectiveness of breaking the series into geometric sums versus using integration, with emphasis on the importance of convergence and accuracy. The conversation highlights that while complex methods exist, simpler approaches can yield correct results.
  • Understanding of harmonic series and summation notation
  • Familiarity with the Euler-Maclaurin summation formula
  • Basic knowledge of integration techniques, particularly for functions like \(1/x\)
  • Experience with geometric series and their properties
  • Study the Euler-Maclaurin summation formula in detail
  • Learn about convergence criteria for series and integrals
  • Explore geometric series and their applications in summation
  • Practice calculating harmonic series sums using different methods
Students in advanced mathematics, educators teaching calculus and series, and anyone interested in numerical methods for summation.
Horse
Calculate the sum of the serie.
\sum^{30}_{i=1} 1/i
I broke the problem into parts. I calculated the sum of the geometric series such as:
\sum^{4}_{i=1} 2^{-i}
\sum^{3}_{i=1} 3^{-i}
\sum^{2}_{i=1} 5^{-i}
\sum^{1}_{i=1} 7^{-i}
and so on for each base with a prime number. Then, I need to sum them to other terms. However, it can be very error-some.
The reason to the question is that I sense that there may be an easier way to calculate the sum. What are the ways to calculate harmonic series? Is my way wrong?
You can use integration by integrating 1/x and making the upper limit 30 and the lower limit 1.
It is a serie, not a continuous function. I have never used integration for series. How does its integration differ from the intregation over a continuous function? Is it an approximated value?
Jesus Christ! Where did you learn this? Are you sure about your method..
Cause i think that its wrong
well this is quite a good sum.
Express 1/2 as 1-1/2, 1/3 as 1-2/3 and so on...
So you will get like
30 -\sum_{1}^{29}\frac{r}{r+1} = \sum_{1}^{30}\frac{1}{r}
Now covert the sigma term on the left from r=1 to r=30( right now its 1 to 29) Once done with that. Take the sigma term on RHS so you will get rsquare upon r+1... and some other term...
Now convert rsqare to rsquare-1+1 and simplify... So on rhs you will r and 1 upon r+1 under sigma and some other term...
Now take all the terms from rhs to lhs except the 1 upon r+1... Thats it...
http://en.wikipedia.org/wiki/Euler%E2%80%93Maclaurin_formula"
You can apply the Euler-Maclaurin summation formula by using that:
\lim_{L\rightarrow \infty}\sum_{n=1}^{L}\frac{1}{n} - \log(L)=\gamma
where \gamma=0.577215664902\cdots is Euler's constant.
What we need to do is avoid using the lower limit of n = 1 in the Euler-Maclaurin summation formula as the series will not converge well. We can write:
\sum_{n=1}^{R}\frac{1}{n} = \sum_{n=1}^{L}\frac{1}{n}-\sum_{n=R+1}^{L}\frac{1}{n}
Where L is larger than R+1 and is arbitrary. Applying the Euler-Maclaurin summation formula to the summation from R+1 to L gives:
\sum_{n=1}^{R}\frac{1}{n}=\sum_{n=1}^{L}\frac{1}{n}-\log(L) +\mathcal{O}\left(L^{{-1}}\right) + \log(R+1) - \frac{1}{2(R+1)}-\sum_{k=1}^{\infty}\frac{B_{2k}}{2k}\frac{1}{(R+1)^{2k}}
Talking the limit for L to infinity gives:
\sum_{n=1}^{R}\frac{1}{n}=\log(R+1) + \gamma - \frac{1}{2(R+1)}-\sum_{k=1}^{\infty}\frac{B_{2k}}{2k}\frac{1}{(R+1)^{2k}}
If we write:
\sum_{n=1}^{R}\frac{1}{n}= \frac{1}{R} + \sum_{n=1}^{R-1}\frac{1}{n}
and apply the summation formula to the summation to R-1, we get a nicer looking formula:
\sum_{n=1}^{R}\frac{1}{n}=\log(R) + \gamma + \frac{1}{2R}-\sum_{k=1}^{\infty}\frac{B_{2k}}{2k}\frac{1}{R^{2k}}
For R = 30, we only need the first 3 terms of the summation over the Bernoulli numbers to get a result accurate to within 10^(-14). Writing out these first few terms explicitly gives the formula:
\sum_{n=1}^{R}\frac{1}{n}=\log(R) + \gamma + \frac{1}{2R}-\frac{1}{12 R^2}+\frac{1}{120 R^4}-\frac{1}{252 R^6}+\cdots
well there is no need to have such complicated solution... Ofcourse its damn right but the method which i have shown is equally correct(thats what i feel)... And we may be able to do it with more ease
30 + 30/31 -\sum_{1}^{30}\frac{r}{r+1} = \sum_{1}^{30}\frac{1}{r}
30 + 30/31 = \sum_{1}^{30}\frac{1}{r} + \frac{r}{r+1}
30 + 30/31 = \sum_{1}^{30}\frac{1}{r} + \frac{r+1-1}{r+1}
30 + 30/31 = \sum_{1}^{30}\frac{1}{r} + 1 - \frac{1}{r+1}
30/31 = \sum_{1}^{30}\frac{1}{r(r+1)}
It is hard to follow. Am I on the right track?
<br /> 30 + 30/31 = \sum_{1}^{30}\frac{1}{r} + \frac{r}{r+1}
<br /> 30 + 30/31 = \sum_{1}^{30}\frac{r+1+r^2}{(r)(r+1)}
<br /> 30 + 30/31 = \sum_{1}^{30}\frac{1}{r} + \frac{1}{(r)(r+1)} + \frac{r^2 - 1}{(r)(r+1)}
Now convert the middle term to 1 upon r+1 minus 1 upon r. And the last term would get converted to r-1 upon r.
Now try doing the sum
<br /> 30 + 30/31 = \sum_{1}^{30}\frac{1}{r} - (\frac{1}{r+1} - \frac{1}{r}) + \frac{r - 1}{r}
<br /> 30 + 30/31 = \sum_{1}^{30}\frac{2}{r} + \frac{r - 1}{r} - \frac{1}{r + 1}
<br /> 30 + 30/31 = \sum_{1}^{30}\frac{r + 1}{r} - \frac{1}{r + 1}
<br /> 30 + 30/31 = \sum_{1}^{30}\frac{(r + 1)^2 - r}{r(r+1)}
It is hard to see where the thing is aiming at.
seems that i have made some mistake... I am working on it though
http://ecademy.agnesscott.edu/~lriddle/series/rear.htm
Well i think i have bitten of more than what i can chew... I have tried every way which is taught to a 12th grader... but in vain... Just have a look at the link
Count Iblis has rather given a very ingenious solution
