Easy 3d Moment with Couples question, Scalar approach.
The discussion revolves around calculating the moment at point A using a scalar approach, specifically in the context of mechanics and statics. The original poster expresses confusion about transitioning from vector to scalar methods for moment calculations involving forces and couples.
  • Mixed
  • Participants explore the scalar approach to compute moments, questioning how to handle forces that do not align with a single axis. There is an attempt to calculate the moment due to a 10 kN force and a discussion about the orientation of resultant moments.
The discussion includes attempts to clarify the calculation of moments and the implications of their orientations. Some participants provide insights on how to represent moments that are not aligned with the axes, suggesting a breakdown into components. There is no explicit consensus, but various interpretations and methods are being explored.
Participants note potential confusion regarding the scalar approach and the need to account for the orientations of moments when summing them. The original poster mentions feeling that they might be missing a concept that could simplify their understanding.
Willjeezy
I'd like to figure out the moment at pt A using the scalar approach, not vector
Vector
M = r x f
Scalar
M = fd
I think I might be missing some concept that would make my life easier...
I figured out how to do this by vector. But I am confused as how to do this by scalar.
for the couple at the top,
My = (2)(2) = 4 j
and then there's a moment at d which causes a rotation in the x axis
Mx= 5 i
The 10kN force can be solved if i put a matching 10kN going up and down at pt A, and then the 10kN pointing down at A and the 10kN pointing up at E would be a couple. However, if I do that the moment calculated is not strictly in one axis.
Kind of confused, I have a feeling I am approaching this wrong.
You can compute the moment of each force "scalarly". But the resultant moments will have different orientations, so you will have to take that into account when you sum them up; which pretty much means you will be treating them as vectors, except that you are going to make a bunch of sign errors.
Hey Voko,
how would I go about figuring out the moment effect of 10kN on pt A. I've tried finding the distance from A to the corner right under e.
= √(2^2 + 2^2)
= 2.8
and then with that length am I able to take the moment of the 10kN force?
M = f d
= (10)(2.8)
= 28
but the problem with this moment is that it is in the x z axis.
Yes, the moment of the 10 kN force is not aligned with any axis. It is at the right angle to Y, meaning it is in XZ plane, and it is at the right angle to AE, which makes it "diagonal" in the XZ plane. The latter means you can represent it as a sum of two moments of equal magnitude, aligned with X and Z axes.
You could have obtained that directly from ##(2, 2, -2) \times (0, 10, 0) = 20(-1, 0, -1)##. Much easier, and no hand waving.
right! thank you.
  • · Replies 21 ·
26K
  • · Replies 22 ·
