(Easy) Calculus problem dealing with a runner
  • Thread starter Thread starter The_ArtofScience
    Calculus
3 replies · 7K views
The_ArtofScience
Water is flowing from a major broken water main at the intersection of two streets. The resulting puddle of water is circular and the radius r of the puddle is given by the equation r = 5t feet, where t represents time in seconds elapsed since the main broke.
When the main broke, A runner was 6 miles east and 5000 feet north of the intersection. The runner is due west at 17 feet per second. When will the runner's feet get wet?
Not exactly sure how to solve this problem but here's all I got:
- Triangle, on the x-axis labelled it 31, 680 ft, on the y-axis labelled it 5,000 ft. The hypotenuse is then 32, 072.1437 ft.
- Diffierientiated x^2 + y^2 = r^2 and got 2x dx/dt + 2y dy/dt = 2 r dr/dt
- Looked back at the equation r = 5t, found r' to be 5, so dr/dt =5
- Just pluged the 5 back in like any algebra problem and got
5,000dx/dt + 31,680(-17) = 5(32072.1437)
dx/dt = 139. 784144
Not sure where I went wrong, I plugged the equation back into r = 5t and got 27.95 -- the book says 25.4154041 minutes so there's something wrong here
Alright, well, I'm not sure if I did this the way you were supposed to, but...
I made equations for the locations of both the runner and the water.
For the runner, his x position: x = 31680-17t, and his y position: y = 5000.
Since the water forms a circle, the equation of which is x^2+y^2 = r&2, the water's location can be written as: x^2 + y^2 = (5t)^2 = 25t^2.
You want to find when the runner's position is the same as the edge of the water's position. So, you take the equations for x and y (from the runner) and put them into the equation for the water, giving you: (31680-17t)^2 + (5000)^2 = 25t^2.
With the help of a calculator and after moving all the terms to one side, you get:
264t^2-1077120t+1028622400=0.
Plug those numbers into the quadratic equation and you'll get two answers for t (in seconds). Take the smaller of those two answers (when the runner FIRST gets to the edge of the water) and divide by 60 to get 25.415 minutes.
Essentially, you are asking for the intersection of two graphs. The circle giving the boundary of the water is x2+ y2= 25t2 and the runners path is given by x= 6(5280)- 17t, y= 5000. Replacing x and y in the circle formula by those gives you (6(5280)- 17t)2+ (5000)2= 25t2, a quadratic equation for t. I see no reason to differentiate. This is just an algebra problem.
Thank you both for making that distinction. I am still scratching my head why this problem was assigned when the chapter is a total mismatch
