Edison effect for Incandescent Bulb?
  • Level: Graduate
  • Thread starter wang0073
    Bulb
3 replies · 5K views · last reply
wang0073
Hi,
I would like to ask a question on incandescent light.
Three panels: a vintage carbon-filament bulb with a metal plate on wires from the base; a glowing mercury gas discharge lamp filament; and two circuit diagrams of a diode tube, one showing electron flow with an ammeter, one showing no current.
From the Thermionic emission (Edison effect), heated tungsten filament emits electrons that could be collected by an anode (like a foil connected to positive voltage).
The wiki also mentions that in order to facilitate thermionic emission, tungsten is often treated with mixture of barium, strontium and calcium.
Does this emission happen in a normal incandescent lamp? In the bulb which Edison discovered the effect, there is a plate(foil) inserted into the bulb from the base, this is absent in normal bulbs. Does the tungsten filament still emit electron in this case? If it does, where would the emitted electron go? Without an anode collector, will they be suspended in the vacuum (assume a vacuum bulb) space inside the bulb?
This further brings up a question to the energy balance (conservation) question in a vacuum bulb:
Equation balancing power input against radiation: I squared times resistivity rho(T(x)) over S, plus S-hat times d/dx of thermal conductivity lambda(T(x)) times dT/dx, equals emissivity epsilon(T(x)) times sigma times T(x) to the fourth. A red callout box reads Thermionic loss? Both electron loss & energy loss.
This is the fundamental equation for all tungsten filament temperature calculation when the inside of the bulb is vacuum, and appears in Irving Langmuir’s 1936 http://prola.aps.org/abstract/PR/v50/i1/p68_1 and numerous others.
Do we need to consider the thermionic effects for an ordinary incandescent bulb? How should we modify the equation above?
Wang
  • Handwritten-style equation: I squared times resistivity rho(T(x)) over S, plus S-bar d/dx of thermal conductivity lambda(T(x)) dT/dx, equals emissivity epsilon(T(x)) sigma (T(x))^4 times circumference c; labelled power input and radiation, with a red callout reading Thermionic loss? Both electron loss & energy loss.
  • Left: black-and-white photo of an early carbon-filament light bulb with a metal plate wire at the base. Right: glowing mercury gas discharge lamp showing a coiled filament with barium, strontium and calcium oxide coating.
  • Three panels: a vintage carbon-filament bulb with a metal plate on wires from the base; a glowing mercury gas discharge lamp filament; and two circuit diagrams of a diode tube, one with electron flow arrows and ammeter, one with no current.
If the filament is hot enough, emission has to happen. However, as the emitted electrons have nowhere to go except back into the filament, and the filament becomes positive due to the emission, they will tend to go back to the filament. There is going to be some equilibrium amount of electron gas in the bulb but most likely not very significant to bother about.
Definite figure?
Dear voko,
I agree very much with your answers and believe that an equilibrium will eventually (and very soon) be reached wtih very small amount of electron gas actually suspended in the vacuum space within the bulb.
There is another Physical Review http://prola.aps.org/abstract/PR/v29/i2/p337_1 (Vannevar Bush, MIT, 1927) which also dealt with thermionic emisson on tungsten filament.
Do you know where can I get some definite quantitative figure/data on the amount of electron emitted and henceafter remain in the vacuum bulb space?
Wang
I would actually be surprised if somebody researched electron emission in an incandescent lamp. On the other hand, the theory required for that is part of the theory required to analyze and design vacuum tubes, and a lot has been written on that. Hopefully that should give some ideas on what to look for.
