Effect of increase pipe diameter on fluid
The discussion revolves around the effects of increasing the diameter of a pipe on fluid dynamics, specifically focusing on pressure, flow rate, and velocity changes when transitioning from a 4" to a 6" diameter pipe. The context includes theoretical considerations and practical implications in fluid flow through pipes.
  • One participant suggests that the pressure of the fluid will decrease with the increase in pipe diameter, questioning the flow rate implications.
  • Another participant asserts that the volume flow rate must remain constant into and out of the pipe, referencing Bernoulli's principle.
  • Discussion arises about the relationship between flow rate, pressure, and velocity, with some participants assuming that velocity decreases as diameter increases.
  • A participant emphasizes that while the mass flow rate remains constant for incompressible fluids, the velocity must decrease when the diameter increases.
  • One participant raises a practical scenario about whether more water will be available at outlets with the increased diameter, leading to a clarification that mass flow rate will not increase.
  • Another participant questions if pressure losses would decrease with a larger pipe diameter, suggesting the use of the Darcy Weisbach equation and Moody chart for further analysis.
  • A participant provides a practical example of needing a larger pipe diameter for adequate volume and pressure in a specific application, likening it to the difference between a water tank and a straw.
Participants generally agree that the mass flow rate remains constant, but there is no consensus on the implications for pressure and velocity, with multiple competing views on how these factors interact with changes in pipe diameter.
Some assumptions regarding fluid incompressibility and the specific conditions of the flow are not fully explored, and the discussion does not resolve the complexities of pressure changes or losses associated with varying pipe diameters.
bellshom
Trying to understand what will happen to the fluid in the following scenario.
Lets say there is a length of pipe with an OD of 4", what would happen if halfway along the pipe the pipe OD increased to 6" (gradual increase).
I believe the pressure of the fluid will decrease, would the flow rate also decrease.
If anyone could explain what actually happens that would be great.
Cheers
So the flow rate remains the same,
What about the pressure and velocity? I am assuming a decrease in velocity.
You should be able to work everything out from the flow rate being the same and that one follows from incompressibility :)
Of course, not all fluids are incompressible, but we are taking about flow through a pipe.
If all else fails - read the instructions (hint: that link I gave you.)
This depends on what you mean by flow rate. You have to be more specific than that. The mass flow rate will remain the same. For an incompressible fluid like water, that means the volumetric flow rate will stay the same. However, that means that the velocity of the flow changes. In your example, the velocity decreases when the diameter increases.
Well here is the situation, I can only change pipe diameter size, looking at changing a section of the 4" pipe to 6". Will more water be avaiable at the outlets with the increase in pipe size, will the pressure increase or decrease.
Unless you think water will magically be created in the pipe, then no more water will be available if you increase the diameter. You will have the same mass flow rate as before. Static pressure would rise.
Okay cheers,
Also would the pressure losses decrease with a larger pipe diameter.
If you increase the pipe diameter, you increase the amount of water a given section of the pipe will hold.If a house is 200 yards uphill from the water meter,you have to lay a inch and a half sized pipe,instead of the normal 3/4 inch pipe,to receive adequeate volume and pressure.It's like having a water tank to draw from instead of a straw.If your hot water is on a circulating system,you can design it the same as the cold.If not ,you have to go with a manifold system.Which is also cheaper and more effective for the cold as well.
If you need easy to use formulas,pick a plumbing code book.
Alright cheers everyone, thanks for the help
  • · Replies 31 ·
