Effect of Instantaneous Velocity Change on Orbit
The discussion revolves around a particle of mass m in a circular orbit of radius R around a larger mass M. The problem involves analyzing the effects of a sudden increase in the particle's speed by a factor α, leading to a new elliptical orbit. Participants are tasked with computing various orbital parameters in terms of R and α.
  • Participants discuss the relationship between the initial circular orbit and the new elliptical orbit after the speed increase. There are attempts to derive the semi-major axis and considerations about the pericenter distance. Questions arise regarding the determination of eccentricity and the implications of the instantaneous velocity change.
Some participants have provided insights into the nature of the new orbit, suggesting that the radius R could represent the pericenter due to the conditions of the velocity change. Others explore the implications of the velocity increase on the orbit's characteristics, noting that the new orbit may not be closed under certain conditions.
There is an ongoing examination of the assumptions regarding the relationship between the initial and final velocities, as well as the definitions of pericenter and apocenter in the context of elliptical orbits. The discussion reflects uncertainty about how to justify certain conclusions regarding the orbital parameters.
PChar
A small particle of mass m is on a circular orbit of radius R around
a much larger mass M. Suppose we suddenly increase the speed at which the mass m is moving
by a factor (that is, v[itex]_{final}[/itex] = α * v[itex]_{initial}[/itex], with α > 1). Compute the major axis, minor axis,
pericentre distance, and apocentre distance for the new orbit; express your answers in terms
of R and α alone
Vis-Viva Equation:
(αv)[itex]_{initial}[/itex][itex]^{2}[/itex] = GM [ [itex]\frac{2}{R}[/itex] - [itex]\frac{1}{a}[/itex] ]
Speed of circular orbit:
v[itex]_{initial}[/itex] = [itex]\sqrt{\frac{GM}{R}}[/itex]
Pericentre distance:
a(1 - e)
Apocentre distance:
a(1 + e)
Semi-minor axis:
[itex]b^{2}=a^{2}(1-e^{2})[/itex]
By inserting the initial orbital speed into the vis-viva equation I was able to find the semi-major axis as required:
a = [itex]\frac{R}{2-α^{2}}[/itex]
The problem I'm having now is that I can't find the semi-minor axis without the eccentricity of the new elliptical orbit, or the distance between the two foci, and I can't find a way to eliminate them.
have you drawn a diagram and labeled everything?
Yeah, but it's hasn't really helped any more than trying to manipulate formulas.
I have an idea rolling around that the since the velocity increased while the particle was at a Radius of R, then R will be its pericenter, which would allow me to find the eccentricity, but I'm not sure if that's right, or how to justify it if it is.
Well at the point it obtains an instantaneous velocity increase it moves off tangent to the circle it was already traveling in, faster than it was going so the inward pull of the gravity will not pull it back to the original path. This means it's not going to get any closer to the larger mass so it's not going to go any faster so it has to be the position closest to the large mass at that point. So go from there.
It's a good idea, and a correct one. The particle starts in a circular orbit of radius R and you're adding to its velocity (KE) in a direction tangent to the circle. There are only two places in an elliptical orbit where the velocity is tangent to the radius vector, and that's at periapsis and apoapsis, and since closed orbits repeat it must be one or the other. Since the new velocity is greater than that required for circular motion, the radius must be increasing from that point as time increases and so it's at periapsis.
If it turns out that the new orbit is not closed (what values of [itex]\alpha[/itex] will cause this?) then indeed, periapsis is the only choice.
Thanks for the help guys.
Glad you got it.
  • · Replies 16 ·
  • · Replies 30 ·
