Efficiency of Triangular Fin for Heat Transfer
  • Thread starter Thread starter Santorican
    performance
The discussion focuses on the efficiency of a triangular fin made from 2024 aluminum, with a thermal conductivity (k) of 185 W/mK, a base thickness of 3 mm, and a length of 15 mm. Given a base temperature (Tb) of 100°C and a fluid temperature (T∞) of 20°C with a heat transfer coefficient (h) of 50 W/m²K, participants calculated the fin heat rate, efficiency, and volume. The final efficiency calculated for the triangular fin is approximately 0.98, using Bessel function solutions for I1 and I0, with mL determined to be 0.201.
  • Understanding of heat transfer principles, specifically fin efficiency calculations.
  • Familiarity with Bessel functions and their applications in thermal analysis.
  • Knowledge of material properties, particularly for 2024 aluminum.
  • Basic proficiency in algebra for solving equations related to thermal performance.
  • Study the derivation and application of Bessel functions in heat transfer problems.
  • Learn about the thermal properties of different materials, focusing on aluminum alloys.
  • Explore advanced fin design techniques to optimize heat transfer efficiency.
  • Investigate numerical methods for solving complex thermal equations in engineering applications.
Mechanical engineers, thermal analysts, and students studying heat transfer who are interested in optimizing fin designs for enhanced thermal performance.
Santorican
A strait fin fabricated from 2024 AL with k=185w/mK base thickness=3mm, length=15mm. Tb=100C and fluid temp is Tinfinity=20C and h =50 w/m^2K. For the foregoing conditions and a fin of unit width, compare the fin heat rate, efficiency, and volume of a triangular fin
eta=1/mL*(I1*2*mL)/(Io*2*mL)
mL=(2h/kt)^(1/2)*L
For I1 and Io I am trying to find the bessel function solutions they give that e^-xI1 and e^-xIo are equal to something given an x.
I assumed that x=mL
When I calculate mL I get that mL=.201
In the back of the book they say that for x=.2 you get that e^-x*Io and e^-x*I1 are .8268 and .0823 respectively.
Now I have tried solving for Io and I1 using algebra but I cannot for the life of me get the right answers.
The answers to Io and I1 are .205 and 1.042 and the final answer for the efficiency is supposed to be around .98.
So solving for Io first I say that x=e^-x*Io now solving for Io yields Io=e^-x*x
Plugging everything in Io=(e^-.201)*.8268=1.01 which is not the right answer so I assume that I am doing something wrong.
Help?
Thank you
Lol, Mech 346?
I googled the same thing and I just figured it out.
If you look at table 3.5 for the triangular fin: nf = I1(2mL)/(mL*I0(2mL))
mL=.201 and 2*mL=.402
I1(.402) roughly= .698/e^-.402=1.04
I0(.402) roughly= .137/e^-.402=.205
Thank you very much, that helped a lot.
