Efficiently Count Bits in 32-bit Integers using Bit Operations
  • Thread starter Thread starter noblerare
    Bit Counting
The discussion revolves around the challenge of counting the number of bits to the left and right of a given '1' in a 32-bit integer using only bit operations, without employing loops or conditionals. Participants explore various methods and considerations related to bit manipulation techniques.
  • One participant inquires about counting bits to the left and right of a '1' in a 32-bit integer using only bit operations.
  • Another participant expresses skepticism about the feasibility of achieving this without loops or conditionals, suggesting that such constraints limit the approach.
  • A different participant interprets the original question as involving counting trailing zeros and proposes that the second part could be derived from subtracting this count from 31.
  • One participant mentions potential assembly language instructions that could assist in solving the problem, though specifics are not provided.
  • Another participant suggests that using native operations like popcnt, leadz, and trailz may yield better performance than custom implementations.
  • A participant expresses interest in seeing a function that adheres to the constraints of no loops or conditionals, noting that they have not seen a practical example of such a function.
  • One suggestion involves splitting the integer into two 16-bit values and using them to index into large lookup tables, although this approach raises concerns about memory requirements.
  • A participant provides a detailed bit manipulation method for counting the number of '1's in a 32-bit integer, indicating that there may be faster methods available.
  • Another participant clarifies that the original question pertains specifically to counting zeros to the right of the first '1' bit, which complicates the use of logical operators.
Participants do not reach a consensus on the best approach to the problem, with multiple competing views and methods proposed. The discussion remains unresolved regarding the feasibility of counting bits under the specified constraints.
Participants note limitations regarding the use of logical operators and the implications of certain operations potentially introducing conditionals, which may affect the validity of proposed solutions.
noblerare
Hi all,
I am wondering is there a way to count the number of bits to the left or right of a given 1 in a 32-bit integer?
For example, if I give the function the number 32 = 0b100000, there are 5 bits to the right of the 1 and hence, 26 bits to the left of the 1.
The catch is, is there a way to do this by simply using bit operations? i.e. no loops or conditionals? Bit operations include: & ^ | << >> ! and ~
Thanks
Technology news on Phys.org
no loops or conditionals sounds unlikely. Not much can be done without 'if' and 'goto'.
Yes, as can all such functions. The question is whether this can be done efficiently.
I'm not entirely sure I understand your function, though. It looks like the first part is counting trailing zeros, and the second part is 31 minus the first part. Is that right?
I have been looking into bitboards in chess programming a bit and found that some newer processors have assembly language instructions that might solve your problem, but I have no specifics.
There are lots of tricks you can use with bit twiddling -- but your probably much better off learning how to invoke native operations rather than trying to roll your own (and you will probably get better performance too) -- functions like like popcnt, leadz and trailz.
I would be curious to see the function -- given there are no loops or conditionals. Clearly that means no implied loops or conditionals (i.e. no function calls, intrinsics or conditional operators). I have heard it said you can do anything with a couple of logic operators but never seen a real example.
You could split the number into two 16 bit values and use each value to index into one of two tables with 65536 entries. If you have the ram, a single look up into a table with 4gb entries would work, although it would take a bit to initialize the table.
Bit twiddling might be faster than the random access lookup into 2 GB too. :wink:
If you really want a popcount function and your compiler doesn't offer you a builtin function to do it, you can do something like this:
Code:
uint32_t evens = x & 0x55555555;
uint32_t odds = x & 0xaaaaaaaa;
uint32_t two_long_counts = evens + (odds >> 1);
evens = two_long_counts & 0x33333333;
odds = two_long_counts & 0xcccccccc;
uint32_t four_long_counts = evens + (odds >> 2);
uint32_t eight_long_counts = four_long_counts + (four_long_counts) >> 4;
evens = eight_long_counts & 0x000f000f;
odds = eight_long_counts & 0x0f000f00;
uint32_t sixteen_long_counts = evens + (odds >> 8);
return (sixteen_long_counts + (sixteen_long_counts >> 16)) & 0x3f;
This computes the number of 1's in a 32-bit word. I think there are faster ways to do it too. This can be used to compute trailz:
Code:
uint32_t find_lowest_one = x & -x;
uint32_t make_all_smaller_bits_one = find_lowest_one - 1;
return popcount(make_all_smaller_bits_one);
You probably get better performance out of writing a divide-and-conquer version directly. A small lookup table can be useful to accelerate things -- also note you can do things like pack a 16-long lookup table of 2-bit entries into a single 32-bit word.
Nice answer Hurkyl but not what the questioner wants - he wants the number of zeros to the right of the first one bit (and hence the number on the other side).
I thought I had figure it out but then realized logical operators aren't really allowed
i.e.
a = b < 3
probably implies a conditional
  • · Replies 30 ·
  • · Replies 66 ·
