What is the best design for an egg drop from gym class bleachers?
The forum discussion focuses on designing effective egg drop contraptions for a science class project, specifically from gym class bleachers. Key designs include a foam or sponge cavity with padding, a cardboard box with clear plastic wrap, and a cone-shaped structure that channels impact forces. Participants emphasize the importance of conducting trials to determine the lightest and most effective design, with suggestions for using materials like helium balloons and soft bumpers to enhance survival rates. Successful examples include using stuffed animals and foam footballs, which have proven effective in previous attempts.
  • Understanding of basic physics principles related to impact and force absorption
  • Familiarity with materials such as foam, cardboard, and parachute design
  • Knowledge of trial-and-error testing methods in scientific experimentation
  • Awareness of design constraints, such as size limitations and weight considerations
  • Research effective parachute designs for slowing descent
  • Explore impact absorption techniques using various materials
  • Investigate aerodynamic shapes and their effects on fall dynamics
  • Learn about weight distribution and its role in stability during a drop
This discussion is beneficial for students participating in egg drop challenges, educators teaching physics concepts, and anyone interested in practical applications of engineering and design principles.
aguinn99
Hello, everyone, I am doing an egg drop for my science class, (not sure where to put it so I put it here, sorry if it's the wrong place.) and I have developed a few designs. I would like to know which you think would be most successful. (Dropped from gym class bleachers.)
Parameters:
Must be smaller than a piece of paper.
Can have parachute.
Must be able to see at least part of the egg.
Design 1:
For this design, I would take a piece of foam or sponge, carve out a cavity for the egg to fit in, fill it with some type of padding, place the egg inside, and make a window on top to see it.
Design 2:
A box made of cardboard, filled with padding surrounding the egg, a window on top, (when I mean window I mean something like clear plastic wrap) With a parachute attached with string.
Design 3:
A paper folded into a cone shape, with padding inside.
An addition, it would be nice to know which is lightest. (there is a challenge to see which is lightest and still survives.)
Thanks in advance. :3
With these things, the trick is to do some trials.
How far the egg has to survive is important ... and remember that you can use the parachute to direct the point of impact.
Will a normal egg-carton be enough to save the egg?
What about taping a parachute to one side of the egg and a soft bumper (foam, sponge) to the other side? Make the chute out of the lightest stuff you can find.
Note: "smaller than a piece of paper" is not much of a restriction - paper is pretty much 2D ... what is the volume limit?
(with those dimensions, could you add a helium balloon?)
Check the exact rules. Are you sure you aren't limited to a single sheet of paper?
How about cutting up a bath sponge or similar to make say 6-8" long spikes. Stick all over the egg. Mainly works as a shock absorber but may also reduce terminal velocity if dropped from height.
There is no width limit, but it has to be smaller than a piece of paper (height and base).
That's probably the best idea, i'll do some testing. But you didn't mention the cone design. I've seen some videos with a cone design and they worked quite successfully. What do you think about that? With the cone design, the point isn't to have a parachute, but for the tip and the padding to take the full force of the impact.
The cute thing about the cone is that the shape channels the initial impact around the egg and guides the air-flow so that the point almost always hits first. Feather the open end of the cone to help. Pad the egg in place.
As usual - do some trials: eggs are fairly cheap.
How much do you really need to pad the egg?
Will you have to allow for bouncing?
Do you have to pass a standard or it is a contest - if a contest, how is the winner decided (some function of weight of container vs height survived so a light contraption that can fall a long way wins?)
What is the highest the test drop will be?
What surface does it have to land on?
I'm not going to hep very much because the point of the project is to get you thinking scientifically about these things.
I've seen the cone idea work well for an 80 ft drop in which you win if the egg survives and you have the shortest drop time. Put fins on it and let it fly like an arrow or rocket. They used several sheets of paper laminated with glue for more thickness.
Edit: the cone needs to crush on impact for energy absorption.
I know I'm supposed to think about it, just asking for a bit of advice for what you think would work best. Trust me, I have a LOT of work I'm doing by myself ahead of me. About the top of the bleachers in my gym is the height, but I'm not sure how tall that is. And there is a graded part, and a contest. The contest is to see which is lightest, but the egg still survives. Thanks for the help so far, I might have a few extra questions, but I need to test right now.
That's interesting, it's just a standard drop though. I'm not sure if I can use a cone now that I think about it, because no piece can break in the air or on impact, but I'm not sure if that counts as "breaking", or just "absorbing impact", and won't affect my grade.
Both my daughters did the egg drop as well. The first one used a box, bubble wrap and a helium filled balloon to slow the descent.
The second one put the egg inside of a large stuffed animal and heaved it over the side.
Both eggs survived intact. :)
Lol stuffed animals is an awesome idea! Thanks for the help everyone!
My idea is a foam football, which I carved out a slot and window for the egg. It survived many times at over the height limit, so I suceeded!
Go stuffed toy! ... and if it sported the logo of your school football team bonus marks?
9K
  • · Replies 16 ·
32K
52K
