Eigenvector Calculations and Verification for y1+y2=5
  • Context: MHB
  • Thread starter Thread starter ertagon2
    Eigenvector
The eigenvector calculations for the equation y1 + y2 = 5 are confirmed as correct, with the characteristic polynomial derived as det(yI - A) = 0, leading to (y - 1)(y - 4) = 0. The eigenvalues of the triangular matrix are 1 and 4, which sum to 5, consistent with the trace of the matrix. The discussion emphasizes the utility of using the trace to simplify eigenvalue calculations without the characteristic polynomial, although the latter is straightforward in this case. Wolfram Alpha (W|A) corroborates these findings for the matrix ((1,0),(3,4)).
  • Understanding of eigenvalues and eigenvectors
  • Familiarity with triangular matrices
  • Knowledge of matrix trace
  • Experience with characteristic polynomials
  • Study the properties of triangular matrices in linear algebra
  • Learn how to compute the trace of a matrix
  • Explore eigenvalue calculations using Wolfram Alpha
  • Investigate the implications of the characteristic polynomial in different matrix types
Students and professionals in mathematics, particularly those focusing on linear algebra, eigenvalue problems, and matrix theory.
ertagon2
Can you please confirm my answer?
det(yI-A) = 0
(y-1)(y-4)=0
y1+y2=5
Yes, it is correct.
Incidentally, did you already learn about the eigenvalues of triangular matrices?
Did you perhaps already learn about the trace of a matrix (= the sum along the main diagonal)?
This could help you to calculate the required quantity without having to set up the characteristic polynomial. (Of course, that is not much work here, either.)
I get the characteristic equation:
$$x^2-(1+4)x+(1\cdot4-0\cdot3)=x^2-5x+4=(x-1)(x-4)=0$$
Hence:
$$\lambda_1+\lambda_2=1+4=5\quad\checkmark$$
W|A confirms our results:
W|A - eigenvalues for ((1,0),(3,4))
10K
