Eigvector/value problem (need validation of my proof)
  • Thread starter Thread starter rock.freak667
    Proof
The discussion centers on validating a proof regarding eigenvalues and eigenvectors of matrices A and B. It confirms that if λ is an eigenvalue of matrix A with eigenvector e, and μ is an eigenvalue of matrix B with the same eigenvector e, then λ + μ is indeed an eigenvalue of the matrix A + B with e as the corresponding eigenvector. Participants note a typographical error where 'x' was used instead of 'e', which could indicate a misunderstanding of the notation. Despite this, the correctness of the proof's logic is affirmed. The consensus is that the proof is fundamentally sound, with minor notational adjustments needed.
rock.freak667
[SOLVED] eigvector/value problem (need validation of my proof)
Show that if \lambda is an e.value of a square matrix A with e as a corresponding e.vector, and [ites]\mu[/itex] is an e.value of the square matrix B for which e is also a corresponding e.vector,the \lambda + \mu is an e.value of the matrix A+B with e as a corresponding e.vector
From the def'n of an e.vector
Ax= \lambda x
Ax+Bx= \lambda x + \mu x
(A+B)x= (\lambda +\mu)x
hence \lambda +\mu is an e.value of A+B
I don't see anything wrong with your proof. Although since the problem defines e as the eigenvector, it'd probably be more prudent (albeit arbitrary) to use that instead of x.
foxjwill said:
I don't see anything wrong with your proof. ... it'd probably be more prudent (albeit arbitrary) to use that instead of x.
I would consider the fact he used x when he should have been using e an actual error in his proof. Yes, it might simply be a persistent typographical error (which is still an error!) -- but it might also be a symptom of a deeper misunderstanding of how to manipulate mathematical statements.
However, I do completely agreement with you that the original poster's proof idea is correct.
ah yeah, a typo, supposed to be e since that is the e.vector.
Ah, there we go. Mystery solved. :smile:
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
