Elastic curve of cantilever beam
The discussion focuses on determining the elastic curve of a cantilever beam using the method of integration, specifically applying the equation EIV''(x) = -M(x). The user seeks clarification on calculating the moment M(x) at the free end of the beam, debating whether to include support reactions in the equation. The final derived elastic curve formula is EIv(x) = (wlx^2)/4 - (wlx^3)/6 + (wx^4)/24 - (M(a)x^2)/2, which is used to calculate total deflection at point A.
  • Understanding of beam mechanics and cantilever beam theory
  • Familiarity with the method of integration for solving differential equations
  • Knowledge of boundary conditions in structural analysis
  • Proficiency in using the equation EIV''(x) = -M(x)
  • Study the derivation of the elastic curve for cantilever beams using EIV''(x) = -M(x)
  • Learn about boundary conditions and their implications in beam deflection problems
  • Explore the role of support reactions in moment calculations for beams
  • Review examples from "Mechanics of Materials" by Gere for practical applications of these concepts
Students and professionals in structural engineering, mechanical engineering, and anyone involved in analyzing cantilever beam deflections and elastic curves.
chris54
Using method of integration, determine the elastic curve for the beam and calculate the total deflection at a point A (end) of the beam. Use EI as a constant.
See word document attached with diagram.
EIV''(x) = - M(x)
I know how to integrate to get the deflection formula but I'm not sure how to calculate M(x) with the moment at the free end.
Is it M(x) = -w/2(L-x)^2 + M(a)(x/L)
or M(x) = -w/2(L-x)^2 + M(a)
Why do some problems in my textbook (Mechanics of materials, Gere) include the support reactions in M(x) and others don't? Do I need to include the support the reactions?
Also will my answer be in meters e.g. v = 100m/EI ?
Any help is much appreciated.
Thanks.
If there's a moment on the free end of the beam, the moment diagram M(x) is constant, right? You can set your coordinate system with a positive direction from the free end to the fixed end, and then use integration to determine w(x). You need a boundary condition to find the constant of integration, which actually equals the deflection at the free end.
Thanks for the reply.
So it will be M(x) = -w/2(L-x)^2 + M(a) ?
It's for an assignment and the question is given with the origin of the coordinate system at the fixed end, so I can't change it. The boundary conditions are v'(0) = 0 and v(0) = 0, so both constants will be zero and I should get:
EIv''(x) = (wL^2)/2 - Lwx + (wx^2)/2 - M(a)
EIv'(x) = (wLx)/2 - (wlx^2)/2 + (wx^3)/6 - M(a)x
The last one will be the elastic curve and then I just sub all the values in, with x=L and I will get the deflection at the free end. Does that sound right?
  • · Replies 17 ·
