Electric circuit how to check linearity
The discussion revolves around checking the linearity of an electric circuit and converting equations from continuous to discrete time. The user questions the correctness of their first equation, suggesting it should represent the derivative of Vc(t). They seek clarification on the discrete time equations, particularly the third equation, and inquire about the meaning of "T" in this context, which is identified as the time step size. Additionally, the user expresses uncertainty about the linearity of the system, noting that the presence of an exponent typically indicates nonlinearity. The response emphasizes that there is no universal method for continuous to discrete transformation, referencing the Euler approximation as an example.
Physicslearner500039
Hi all,
I found the following equations for the electric circuit shown
Vc(t) = - 1/(R2*C) * Vc(t) – 1/C * i(t) --------------------1
Vt(t) = Vc(t) – R1*i(t) ------------------------------------ 2
I have the following questions
1.The first equation should be dVc(t)/dt = -1/(R2*C) * Vc(t) – 1/C * i(t) . Am I correct on this?
2.The discrete time equations are given in the documents as
Vc,k+1 = exp(-T/(R2*C)Vc,k – R2 * (1 – exp(-T/R2*C)*ik --------------- 3
Vt,k = Vc,k – R1*ik; ------------------------------------------------------------- 4
I can understand the 4th equation, but I cannot understand the 3 equation, could someone guide me how to do this conversion from continuous to discrete.
What is the “T” that is used?
3.Is this system linear? From little understanding I have, when an exponent is involved generally it is nonlinear. What is the methodology I should adopt to check whether a system is linear or nonlinear?
thanks in advance,
Regards
The T is probably time step size.
There is no general way to transform continuous to discrete. For example, the Euler approximation difference equation is:
df(t)/dt = f(T)-f(0)/T where T is the time step size, t is time, and f(t) is any function of t.
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
