Electric circuit - time constant to charge
6 replies · 7K views · last reply
seb26
Four identical capacitors are connected with a resistor in two different ways. When they are connected as in part a of the drawing, the time constant to charge up this circuit is 0.91 s. What is the time constant when they are connected with the same resistor as in part b?
http://edugen.wiley.com/edugen/courses/crs2216/art/qb/qu/c20/ch20p_99.gif
Q=Q0*(1-e-t/RC)
Q0=CV
t=RC
a) Q0=Q/(1-e-ta/RC) = 4C/V(1-e-ta/RC)
b) Q0=Q/(1-e-tb/RC) = 5C/2V(1-e-tb/RC)
4C/V(1-e-ta/RC) = 5C/2V(1-e-tb/RC)
4/(1-e-ta/(4ta)) = 5/2(1-e-tb/(5/2tb))
e-2/5 = 3/8 + 5/8 * e-1/4
I'm stuck there.. Not sure if what I did is right.. If it is, I can't find a way to use the natural logarithm
You don't need the equation giving the charge at a certain time because the question doesn't ask you to find the charge at a certain time. Just write out an expression for the time constant for (a), then do the same for (b). Solve the two resulting equations.
I tried using the equation t=RC because Ra = Rb; Ca = 4C and Cb= (5/2)C
R= ta/4C = 5tb/2C
tb = (5/8)ta
Why doesn't this give me the right answer?
I can't find another equation to solve for tb.
4/(1-e-ta/RCa) = 5/2(1-e-tb/RCb)
e-2tb/5RC = 3/8 + 5/8 * e-ta/4RC
I'm stuck there again..
Recalculate Ca.
Again: you do not need the time dependence of charge. By the way, you use wrong formulas. The time constant is T=RC. Ta= RCa, Tb=RCb. Ta is given: 0.91 s. Tb/Ta=Cb/Ca.
ehild
When the capacitors are connected in parallel the total C is C1+C2+...+Cn which in case a) gives 4*C..
And i did use tb/ta = cb/ca
tb= taCb / Ca = ta(5/2)C / 4C = 5ta / 8
I used the equation with the charge because if there's a way to take the natural logarithm the charge would cancel.
The four capacitor are not connected in parallel in case "a".
Q(t)=Q0*(1-e-(t/RC) ) = Q0*(1-e-(t/T) ) is the formula for the time dependence of the charge on the capacitor. t is the time after connecting the capacitor to a voltage source. T is he time constant .
ehild
