Hello louza8,
Part of your calculations show:
[tex]\ln \left( {\frac{5.727 \ \mathrm{x} \ 10^{-3} \ [\mathrm{C}]}{8.1 \ \mathrm{x} \ 10^{-3} [\mathrm{C}]}} \right) (850 \ [\Omega]) (4.62 \ \mathrm{x} \ 10^{-6} [\mathrm{F}]) = -t[/tex]
[tex]t = 0.00168 \ [\mathrm{s}][/tex]
Check your math. Something is not right with your final value of
t.
Then later you assume that
[tex]I = \frac{\Delta Q}{\Delta t}[/tex]
But your following calculations assume that charge
Q is linear with time
t. But I assure you it is not! Charge
Q is an exponentially decaying function with time!
But if you
must take this approach (which I don't necessarily recommend doing by the way -- pat666's solution is much easier), you can do it by finding the instantaneous current.
You already know that
[tex]q(t) = q_0 e^{\frac{-t}{RC}}[/tex]
So take the derivative with respect to
t,
[tex]\frac{d}{dt}q(t) = -I(t) = q_0 \frac{d}{dt} \left( e^{\frac{-t}{RC}} \right)[/tex]
then use that to find the instantaneous current at time t
1/2 (but again, you'll have to fix your calculation of this t
1/2 value, because there is a mistake in your previous calculation of it, above).
Finally, plug that into
Ploss =
I2R, and you'll get the correct answer.
But as I said before, although this works, there is a much easier way to handle this problem that doesn't involve calculating any derivatives or anything.
