Electric Field along bisector of charged line (w/error)
The discussion focuses on calculating the electric field along the perpendicular bisector of a uniformly charged line of 35 nC distributed over a 230-mm length. The participants derive the electric field equations using the formulas dE=kλdx/r² and E=kQ/r², ultimately approximating E as Eapprox=315/y². They identify that the error in approximation reaches 5% at a distance of approximately 0.36 m from the line charge. The conversation highlights the importance of considering the correct components and mathematical refinements in electric field calculations.
  • Understanding of electric field concepts and calculations
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of electrostatics, including charge distribution and field equations
  • Proficiency in using mathematical tools for solving equations
  • Study the derivation of electric fields from continuous charge distributions
  • Learn about the impact of distance on electric field strength
  • Explore the use of integral calculus in physics problems
  • Investigate error analysis in approximations for physical models
Physics students, electrical engineers, and anyone involved in electrostatics or electric field calculations will benefit from this discussion.
Slightly Odd Guy
You wish to determine the electric field magnitude along the perpendicular bisector of a 230-mm line along which35 nC of charge is distributed uniformly. You want to get by with a minimal amount of work, so you need to know when it is sufficient to approximate the line of charge as a charged particle.
At what distance along the perpendicular bisector does your error in E reach 5 % when you use this approximation?
dE=kλdx/r2
E=kQ/r2
λ=Q/L
If I do the approximation part first, I get:
1. Eapprox=kQ/y2
Plugging in the values (minus units at this time):
2. Eapprox=315/y2
So now I work on the Eline-charge.
Because point P at distance d is along the bisector of the line, I know that Ex cancels itself out. All I need to worry about is Ey.
3. dE=((kλdx)/(x2+y2)2)*(y/(x2+y2)1/2)
4. dE=(kλydx)/(x2+y2)3/2)
5. E=kλ∫(ydx/(x2+y2)3/2
I punch that through an integral calculator, and I get
6. E=kλ[x/y(x2+y2)1/2] ---- evaluated from -L/2 to L/2
Now I start to plug in all the values (minus the units for the time being) and I get
7. E=1370[0.23/(y(.013+y2)1/2)]
8. E=315.1/(y(.013+y2)1/2)
Okay.
Now I'm working on finding the approximate error.
error=(|Eapprox-Eexact|)/Eexact
I know the error (5%) and now I want to solve for y at that error.
9. 0.05=|315/y2-315.1/(y(.013+y2)1/2)|/315.1/(y(.013+y2)1/2)
This is pretty nasty, so I plugged it in the Mathway calculator and it promptly informed me there are no solutions.
That sums up what I've done. Where am I going wrong?
Thanks,
SOG
I suspect you are going a much more elaborate path than intended. The objective is to avoid such complications.
Where does the error come from in pretending the charge is a point particle? Can you think of a simple geometric argument for deciding when that error will be less than 5%? I don't think you need to be too precise about it, just able to say "when the distance is more than ... the error will be less than 5%".
Well... I could probably compare the radii for both. In which case, I would have:
0.05 = |d2-(d2+0.013)|/d2
0.05=0.013/d2
d=0.51 m
Am I on the right track there?
0.05=0.013/d2
d=0.51 m
That's what I had in mind, except I'm not sure how you arrived at 0.013m. That's a lot less than half 230mm.
0.013m2 is ~ (230mm/2)2.
I switched some numbers around in my second post, so it screw some more things up. I think it's supposed to be:
0.05=|d2-(d2+0.013)|/(d2+0.013)
in which case it gives d=0.501m,
which is wrong.
Ah, sorry - didn't notice it was not squared in the equation you wrote. So, yes, I think that's fine.
If you wanted to refine it some, you could show that 1/r2 at the point half way from the middle of the charge to one end is more than the average of the values at the middle and at the end respectively. But that's probably overkill.
[Edit: I've not checked this carefully, but I think this argument might allow you to use 0.013/4.]
which is wrong.
Oh - so you know what the answer is supposed to be?
I don't, unfortunately. My online homework only tells me that it's wrong.
The refinement I suggested in post #7 gets it down to 0.26m. The exact value is about 0.21m.
Ok, the correct answer is d=0.36m. I don't know how they come up with that answer.
I just realized what we both forgot, to take only the component in the x direction. So we should use 1/r3, not 1/r2.
  • · Replies 32 ·
