Electric field and electric charge inside the Earth?
Charge on a conductor typically resides on its surface, leading to zero internal charge and electric field, a principle that applies to metals. However, the Earth, while a good conductor, has complex internal structures that include both conducting and non-conducting materials, resulting in a non-zero electric field in certain areas. The Earth's magnetic field, generated by circulating charges in its molten core, indicates that there are indeed non-zero charges present. This complexity means that while local regions inside the Earth may approximate the behavior of conductors, they do not conform to the idealized models of simple conductors. Understanding these nuances helps clarify the apparent contradictions between theoretical concepts and the Earth's actual behavior.
Hardik Batra
As we know, If you put charge on conductor then all the charge reside on the surface of the conductor and charge inside the conductor is zero and electric field is also zero.
Earth is also a good conductor. So the charge resides on the Earth surface?
Is there no charge inside the earth?
And Electric field is zero inside the earth?
Close to zero maybe, but not exactly zero. Earth has a magnetic field that is generated by the circulation of charges deep inside the liquid molten core. The existence of that magnetic field tells us that the charges must be nonzero.
Read about the geodynamo on wikipedia.
So there is contradiction between metal conductor and Earth conductor.
Because it is zero in metal but not in Earth but both are good conductor.
And the property of the conductor says that charge always resides on the surface of the conductor but it is not happen in case of earth.
Then how to understand this.
It is not a contradiction. It is a question of complexity. A conducting metal sphere (including Earth) has zero internal fields. However the Earth has many internal materials, some conducting , some not. The materials move. Some have piezoelectric properties.
The total internal charge of a local region inside the Earth is thus approximately zero but not exactly zero. You could also say that most .ocal regions are approximately conductors.
Whenever you mix up idealized theoretical concepts with real life, you risk confusing yourself with apparent contradictions that are not real. Few things in real life are ideal or pure.
Likes Hardik Batra
  • · Replies 21 ·
