Electric Field and Potential in Spherical Shells
6 replies · 8K views
rizardon
Consider two thin conducting spherical shells. The inner shell has a radius r1=15cm and a charge of 10.0 nC. The outer shell has a radius r2=30cm and a charge of -15.0 nC.
Find
a)the electric field E and
b)the electric potential V in A, B and C, with V=0 t r=infinity
A: r<r1
B: r1<r<r2
C: r>r2
E=kq/r2
V=kq/r
Using the above formula, I get
For the region A
E=0 and V=0 because the charge within a conducting shell is 0
For the region B
E= k(10 nC)/r2, r1<r<r2
V= k(10 nC/r
For the region C
E=k (10 nC + -15 nc)/r2=k(-5 nC)/r2
V=k(-5 nC)/r
Am I doing it the right way?
E looks okay, though I'm not sure if you think in the right way or not. But V is not :smile: Remember that only V(infinity) = 0. You should find the potential difference instead.
Have you learned the Gauss law yet?
Yes, I have, but using the law is quite confusing. How will finding the potential difference make any difference, since my Va would be 0 and what's left is Vb which is kq/r?
The formula E = kq/r^2 only applies to charge points, not a distribution of charges. In this case, where symmetry is present, you should apply the Gauss law. Consider a spherical surface concentric with the shells.
Again, the formula V=kq/r only applies to charge points. To find V, you should apply the original formula: dV = -Edr. Va=0 only if a=infinity, so you must do the integration from r to infinity.
EDIT: Forgot to mention something. After using the Gauss law, you should find that the formula of E looks similar to E of a charge point. That's why you got right answers for E :smile:
The equations you have mentioned are not appropriate here.
You'll need to use Gauss Law to find the field in the three regions you've mentioned.
Do you know how to use Gauss law? Look into your book if you don't.
Do you know how potential is related to the field?
The potential difference is V=k(integral)dq/r
V=-(integral)Eds=-(integral)Edr=-(integral)kQ/r2dr=-kQ(integral from a to b)dr/r2=kQ(1/b - 1/a)
Is this right
Is this right
Only when E=kQ/r^2 from r=b to r=a :smile:
What if E=kq1/r^2 from r=b to r=c, and E=kq2/r^2 from r=c to r=a?
